why doest my tach work??
Old 09-15-2009, 11:20 AM
ryans01z28's Avatar
Default why doest my tach work??
just put my motor back in last night & fired it up & the tach doest work. is there a harness that I missed somewhere???
Old 09-15-2009, 11:21 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Check your cam position sensor and wiring. That's the most common cause of sporadic and/or missing tach issues.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-24-2009, 11:15 PM
ryans01z28's Avatar
it was the cam sensor wire but i still have a ses code that says cam sensor, random misfire, misfire, and tps (4codes)
Old 09-26-2009, 06:22 AM
frankmarroquin's Avatar
Check for any loose grounds, and also make sure the pigtail on the pass side by the battary is connected. Think it is orange...
Old 09-26-2009, 09:57 PM
ryans01z28's Avatar
I just cleared the code & its good now
Old 09-26-2009, 11:20 PM
Pro52R's Avatar
I'm having the same issue.
What pigtail??
Also, my temp gauge isn't working.
And.....I'm not throwing a Ceck Engine Light
Old 09-27-2009, 05:26 PM
ryans01z28's Avatar
geeze now it says o2 sensor right bank along with the other codes
Old 09-27-2009, 11:01 PM
ryans01z28's Avatar
does anyone think its just because i havent got the car tuned after the heads and cam swap>
