11 Second Club - Can i expect 11's
View Full Version : Can i expect 11's
SVTFAN09
09-15-2009, 03:35 PM
I have a pt4400 stall, 3.73, uca,lca, cutout,lid, futraltune, drag shocks,et streets, i have front sway bar removed.
Could i see 11.4-11.7's
jitsumania
09-15-2009, 05:19 PM
Depends on what kind of engine mods you have. Based on what you listed by itself I don't think so. Getting into the 11's usually will require at least some top end and/or bottom end modifications or power adders. Suspension mods are good for hooking but you need the HP/TQ to make 11's happen. Head and cam combo may a good option for you next mod. Have Patrick G. on this board spec you a good cam, you won't regret it. Good luck and hope I'm wrong so you can get into the range you want.
MurderedOut
10-14-2009, 03:25 AM
high 11s maybe. Theres many different variables. a cam would get you into the 11s no prob
slowlsx
10-27-2009, 10:26 PM
full bolt ons, good tune, drag radials and that big stall you should definately see 11's.... i have seen it before
Magnet
10-27-2009, 10:53 PM
Do you have exhaust and other bolt-ons? All you listed was suspension.. although that stuff is all great, if that's all you have you won't make 11's. My guess is a mid 12.
With full bolt-ons you will probably be looking at bottom 12's to high 11's at full weight.
zach_ws6
10-28-2009, 12:19 AM
if you have full exhaust and possibly a good tune...its could happen. high 11s that is.
