Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro 1990 to 2002 How to Make LED Turn Signals<br>Step by step instructions for do-it-yourself repairs.
LED Turn Signals??
It's an el-12 flasher that you'll need. It's an electronic flasher, not thermal like the stock ones. LEDs won't flash with the thermal ones. You can get these at autozone. Made by Tridon, I believe.
here is the link to my write up... its for a camaro, but im sure u will get an idea if you want to do it....
https://ls1tech.com/forums/appearanc...very-easy.html
I was always under the impression that the EL-12 is the "go-to" flasher for LED applications. There seems to be some conflicting results because each set of LEDs you go with are different. My suggestion would be to just try it out. They're cheap so it's not really a huge loss if it doesn't work. If that doesn't work, there are no load flashers which should do the trick.
Links used...
https://ls1tech.com/forums/stereo-el...d-flasher.html
https://ls1tech.com/forums/appearanc...-problems.html
Links used...
Yeah. There's a flasher for your hazards too though. I would wait till someone else chimes in though because I have yet to do this. It's been on my list for a while, but I was just going to replace all lights with LEDs and plug in the EL-12 for the turn signals and hazards.
I just replaced all the bulbs (front & back) with led bulbs from a company called superbrightleds.com, and both flashers with electronic. Everything worked.. even the DRL still work although I expected they wouldn't!
It's a good idea to get led bulbs that shine sideways as well as forwards, (some don't, or not much) because otherwise all the lamp area isn't lit fully with leds.
kr D.
im gonna use these bulbs
http://cgi.ebay.com/400-X-5mm-Flat-T...4.c0.m14.l1262
and make the turn signals myself so i still need a few supplies
http://gallery.me.com/bradleymarreno/100010
you can check out my turn signal i did there. unfrtunately its for my 95 but youll get the idea. im using a PWM so that theyll be dim with the running lights and get brighter when the signal flashes.
