Radiator fans affecting track times !!
One of my friend used to do a constant 10.9 quarter mile runs
ones he tried to make his fans working at full speed before the run using hp tuner his time dropped to 11.3 in the same day same weather
any body tried this before ?
we didn't expect this drop in performance due to amperage drop caused by fans
Do the math...
If the alt is full fielded, and putting out 140A, @ 13.5 volts, the wattage is 1890.[volts x amps= watts] Converting that to HP= [1890x.001341]=2.53 HP. And, that 2.53 is not the added HP loss, as there's already a load of some amt on the system.
That's not likely to be the cause of the loss in performance.
Other causes:
Lower volts to the ign.?
Low volts to the fuel pump.?
PCM incapable of sufficient inj voltage correction?
Other causes:
While true a loaded alt does pull on an engine, listen as you hook up a jump start on a dead battery, in this case it seems logical its probably an overall voltage issue as geezer stated. Electronics run better and more efficiently with more voltage.
If the fans were running full tilt at wot down the track, they become a major restriction, it is like hitting a brick wall of air. That is why there is hysteresis in the software to shut the fans down at a certain mph, they would become more of a hinderence then help at speed.
