Drag Racing Tech - how front SEAT BELTS come out???
nemss1
09-16-2009, 02:05 PM
im getting kirkys and harnesses and wanted to know how to remove the front seat beats. help is greatly appreciated. thanx
streetassasin
09-16-2009, 02:07 PM
T47 torx (I hammered on a t50) on the floorboard and you drop the headliner down and its held in by 2 bolts on the roof, I wanna say 12mm but not too sure
nemss1
09-16-2009, 02:43 PM
Ok thanx bro. I got out everything except for the fronts. Gonna get them out today
JUICED96Z
09-16-2009, 03:06 PM
Don't slip on the torx....... it hurt's............ spray some liquid wrench or PB blaster around it and let it saok... that helps........ you can then remove the little mount that the torz is threaded to when you are done.
nemss1
09-16-2009, 04:35 PM
where are the mounts that u are talking about? i know the bottoms of the seatbelts use a torx but i dont get what mounts u are talking about
JUICED96Z
09-16-2009, 05:52 PM
The mount is what your seat belt mounts to on the floor...... you will see it when you pull the seat belt out. It is maybe a pound :D
That torx bolt looks like it goes threw the floor but it does not. It goes threw the mount. The mount is bolted to the car.
nemss1
09-16-2009, 07:07 PM
Ok thanx man, ill check it out tomorrow
Z28/2002
09-17-2009, 09:06 AM
It's a 13mm
:thumb:
streetassasin
09-17-2009, 09:11 AM
I was close :jest:
camar0corey
09-17-2009, 11:37 AM
I'm kicking myself cause I had my headliner replaced, and I have a harness on the driver side. I should have took the driverside belt out before hand and had them make that solid. What are you all doing for the space in your headliner, or does that little cover still stay in place up there?
Whats one front seat belt weigh anyway? Looking at getting a seat and harness someday for the passenger side also, curious how much more weight is going bye bye.
nemss1
09-17-2009, 12:52 PM
good question about the cover. id like to know as well
Beaflag VonRathburg
09-19-2009, 03:54 AM
Mount wise are you talking about the black ring / spacer type things?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
