stock-appearing sleeper
Old 09-16-2009, 06:03 PM
intenseblue's Avatar
Default stock-appearing sleeper
Definates:
Assembled 243 heads/LS6 Cam
Lid/Filter
Catback
Off-road Y
Tune
Maybes:
LTs
Underdrives
Unlisted necessities: ??????
This is where LS1 Tech becomes handy
Power expectancy?
01 T/A M6 made 297 stock on K&N only
Old 09-16-2009, 06:11 PM
slt200mph's Avatar
Around 350
streetassasin's Avatar
IMO a badass sleeper would be a car with a forged 347, nitro daves money maker, cheatr cam, lid and an e cutout
Old 09-16-2009, 06:15 PM
Am I going to need anything to run the head/cam swap if I go with LTs and full exhaust?
Clutch and injectors were my main worry
Old 09-16-2009, 06:20 PM
Bader-X's Avatar
a better one in my opinion
PRC stg 2.5 241 castings without the 241 number removed milled
cometic .040
custom stealth cam and pushrods
ORY or just cats removed
3" DMH cutout
ported fast 92 with removed writings and flat black paint or a stock ls6 with 90mm tb or the oval one from tpis
pulley
any lid that is black without any sticker (try to put a new stock sticker on it LOL)
aluminum flywheel or a billet one
free mods
a hidden dry shot if ok with that
383 - 396 stock ls1 block or resleaved for a 427 and above
just some thoughts.
Old 09-16-2009, 06:25 PM
cometic .040
3" DMH cutout
pulley
free mods
just some thoughts.
Should have mentioned my budget...sorry $2000 at least- $2500/3000 tops
Like for it to be as low as possible. How much difference would the headers make?
Old 09-16-2009, 06:30 PM
eseibel67's Avatar
Headers will make a big diff in a performance engine, but it wouldn't look stock.
Old 09-16-2009, 06:50 PM
Is 350 on par with Z06s?
Old 09-16-2009, 06:56 PM
slt200mph's Avatar
Stock 2002-2004 Z06 vettes put 345-360 to the wheels ... your stock injectors will work fine
Old 09-16-2009, 07:13 PM
Skeet Skeet's Avatar
Originally Posted by slt200mph
Stock 2002-2004 Z06 vettes put 445-460 to the wheels ... your stock injectors will work fine
Where and the hell do you get that power level from. The injectors will be good till then but stock they def will notmake that kind of power. OP I say hide a nitrous kit, port and mill your stock heads and do all the boltons that you can without being noticed
Old 09-16-2009, 07:40 PM
slt200mph's Avatar
excuse the typo... I corrected it for your viewing pleasure
Old 09-16-2009, 07:41 PM
slt200mph's Avatar
excuse the typo... I corrected it...while I'm here I'll help you too..it is where IN the hell .... NOT ... where AND the hell .... (:
Old 09-16-2009, 08:24 PM
Bader-X's Avatar
ok stock 241 ported by PRC on stock valves and milled with .040 gaskets
custom stealth cam or off the shelf , pac springs or comp 918 and pushrods
remove what you want just writing some options and thoughts
headers is what he said will give a very good amout power wise and reducing times at the strips or cars lengths on the street but it will not look stock
if you go the hidden nitrous way you can cancel many things and just spray 50 hp more ^_^
Old 09-16-2009, 08:45 PM
DVS99TRANS's Avatar
You could go with something like my setup, it does sound like there is something but not a 500whp/480wtq car. I had alot of people trying to call me out with high 12 second cars because it sounds like a small cam basicly. The combo also smashed a 600RR from a 65 roll also. If i was still running cats, it would be super quite but still lobes a little though. I think that is a little beyond the route your going to take unfortunately.
But with the ory, people will call you out saying it isn't stock. the car will get a hell of alot louder when you put that on too. The true way to get a sleeper is to forge the motor, steath cam, good set of ported heads, and spray the **** out of it. As soon as you put on longtubes and/or remove the cats, people will catch on really quick though.
A C5 Z06 is alot lighter than you are too, but since you are a m6... All Z06s are m6 also, so it will really come down to a driver's race with the mods you have listed above. Just because someone has a Z06, doesn't mean they know how to drive it
