Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Do ALL CTS-V's have LSD??? Need Help
Old 09-16-2009, 06:43 PM
gruppe5's Avatar
Default Do ALL CTS-V's have LSD??? Need Help
I dont own one but I have a rear diff, took the diff out and looks to be a standard open diff?? As far as I know all CTS-V's have limited slip rear diffs. I do have VIN from donor vehicle and I was present when it was removed so I know it was from a V. Photos would be nice.
Thanks, ( BTW I am searching for the answer )
Old 09-16-2009, 07:48 PM
SkullV's Avatar
All CTS-Vs had limited slip diffs however they shared carriers with the SRX and CTS. The car may have blown a diff out of warranty and the owner got a CTS-SRX diff because it was cheaper.
Old 09-16-2009, 08:34 PM
gruppe5's Avatar
Diff isn't blown, I more or less would like to know how this particular diff functions, since it appears very similar to a standard open diff. I did find that the spider gears dont turn with hand pressure like an open diff though. I have never seen a LSD that looked like this one, all have had either clutch packs in the center or have been a torsen style with worm gears and such.
Old 09-16-2009, 08:48 PM
jerrad's Avatar
Originally Posted by gruppe5
Diff isn't blown,
What skull is saying is that when the V had the diff replaced the dealer might have used a cts-srx diff. So they installe dthe cts-srx into the V under warranty.
Old 09-16-2009, 09:08 PM
gruppe5's Avatar
This was the diff that was replaced under warranty. Trying to figure out where the clutch pack is, I am used to seeing them in the center, appears they may be behind the differential side gears?? Hard to see without disassembly.
Old 09-16-2009, 10:24 PM
jerrad's Avatar
You might PM "V series tech" on here and see if he can give you a pic or two.
Quick Reply: Do ALL CTS-V's have LSD??? Need Help
