Drag Racing Tech - New best 60ft. and ET,cam only
StreetStalkerZ
11-30-2003, 08:43 AM
Well im happy but im not. I was exspecting the new Pro Stock converter to give me a little more ET over my TCS 4400 but i only gained 60ft. and lost topend. I should have a PT 4400 in the car next week because mike and i are thinking with my setup the shift extentions (5100-5200) are to low for my cam. Anyway here is my new best.
60ft. 1.52
1/8th 7.26@92.3mph
1/4 11.48@116.52
I nailed down 3 1.51 60fts. on my stock 10 bolt lol and my worst 60ft. was a 1.58 spinning pretty good off the line. This converter launches very hard but to me it has no topend pull in 3rd gear going by that i lost .15/2 mph over my TCS 4400 from the 330 mark to the 1000ft. but the PT 4400 should cure that :)
CamaroCain
11-30-2003, 10:31 AM
I found out the PT4400 60' just as well as the PS4400. I pulled a 1.50 60' at the Thunder Shootout, and that was on DR's with 3400+ raceweight in my stock internal car. Just make sure you put some miles on it before taking it to the track. Congrats on your new best.
Frank95z
11-30-2003, 12:22 PM
Good job Scott. This Saturday i got out to NPR and at 1pm with the temperature 60 and low humidity I ran 11.40 116.59 with a 1.483 60ft. Half track was 7.19 93.98. If I could have run in the morning when it was cold i believe i could have run a high 11.20. Frank95z
DMcRacer
11-30-2003, 01:15 PM
Very nice. It will be interesting to the results from the PT 4400. I ran two back to back 11.48's out of the right lane, then decided to give the left a try. Thats when we lined up. It looked like people were getting worse 60ft's and running a little slower in the left lane. I decided to launch a little softer because I was worried about spinning. Pulled a 1.566 vs 1.545 & 1.539 out of the right lane, but ran 11.46. Which lane do you run your best in ?
Frank95z
11-30-2003, 01:29 PM
DM Racer I'm not sure if you're talking to Scott or Me. I am Frank and run the Vig3200 with the 1.48 at NPR. If you're refering to our track I ran 11.40 and 1.48 in both lanes. One was 1.483 and the other was 1.485. Scott I'm not jacking your thread when you get your converters sorted out i look for 20's out of you also. :D Frank95z
DMcRacer
11-30-2003, 01:46 PM
Sorry Frank, I was talking to Scott. NPR is an awesome track, but its 8hrs from my house :eek2:
StreetStalkerZ
11-30-2003, 01:49 PM
DMcRacer,The left lane gave me my best ET but later in the night both were equal to me but i was on ET Drags. The humidity ruined my chances on my last run to run a faster 11.40s :( I pulled a 1.51 60ft. on my last pass but i could feel the car was not crossing hard enough for it,11.50@116.11.
Frank,i think at best the PT 4400 will give me back with i lost from the TCS 4400 leaving me around the low 11.30s mark and maybe with some luck i could scratch a 11.29. I also plan to put some long tubes on the car in a few months before the weather goes away so who knows.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
