6.0L heads on a 5.3 LM7...
Old 09-16-2009, 10:38 PM
pdbq's Avatar
Default 6.0L heads on a 5.3 LM7...
I'm thinking that this could be a budget turbo LSX project in the near future so what would the compression ratio be if I put some 6.0L iron heads on a 5.3L truck motor? Thanks!
Old 09-16-2009, 11:56 PM
ramdaspadhye's Avatar
LOW, lol. Stock 5.3 heads are 61cc, and the 317 castings are 71-72cc
Old 09-17-2009, 11:53 AM
5_02ls1's Avatar
theres a guy on here with that same setup in a nova...with an ls6 cam and 15psi it put 640 to the tire and has held together for 3 years......im wanting to say cr would be around 8;5...dont hold me too that though....
Old 09-17-2009, 03:45 PM
NemeSS's Avatar
Its right around 8:1 iirc, but def. less than 8.5:1 for sure
Old 09-17-2009, 04:28 PM
wow, 650hp on a stock 5.3?
Old 09-17-2009, 04:39 PM
NemeSS's Avatar
iirc some guy on turboforums is laying down over 700rw and with a 4.8
Old 09-18-2009, 09:52 AM
xlcooplx's Avatar
i know quik's truck has a 4.8 and a HUGE turbo...iirc, he was pushing over 600RWHP
Old 09-18-2009, 07:43 PM
pdbq's Avatar
I see a lot of varying info here from 8.5:1 to 8.1:1. Are those iron truck heads much more different than the aluminum heads? As I recall, I have the 873 casting that came off a 99 Silverado. The reason that I would like to use these iron heads would be because it would be wasteful to just throw these great heads away, let alone sell them for $20 to a scrap yard... IMO
Plus one of my friends has a Trans Am with some PERFORMANCE iron heads (230 CC) on a 355 and can push about 600 rwhp on pump gas.
Old 09-18-2009, 07:46 PM
pdbq's Avatar
And from what I hear, the 4.8L/5.3L casting has a much thicker cylinder wall than the 6.0L iron block and LS1 so that would mean you should be able to push much more boost through it before you would have problems. Sounds like that would be a nice budget turbo project...
Old 09-18-2009, 09:49 PM
I'm not worried about the cylinder wall thickness as much as I am the crank/rod holding together. That's a shitload of power for a stock setup. I mean if its been done over and over I can see trying to duplicate it. But personally, I think I'd stay to around 500-600whp.
Old 09-18-2009, 10:16 PM
pdbq's Avatar
I've heard that the stock crank and rods can hold up 600 whp just fine. That would be more than enough for a street/strip set up in something like a light short bed pickup. I can get a low mileage long block 5.3L for $100 RIGHT NOW and slap my 6.0L iron heads right on!
I also have a neighbor that is selling a one owner super clean 84 S10 for $300. Motor has 344,000 miles and burns oil so it is pretty much done for. It even has A/C! For that price, this truck would be a hell of a boosted low budget sleeper project and daily driver (after I sell my 98 Z28).
Old 09-19-2009, 01:33 AM
Hell yeh it is, I'd jump on that fast.
Quick Reply: 6.0L heads on a 5.3 LM7...
