Drag Racing Tech
How hard is it to make your car work on 17" drag radials?
Old 09-17-2009, 01:36 PM
CaMaRo67RS355's Avatar
Question How hard is it to make your car work on 17" drag radials?
i know there are a few guys on here that run 17" drag radials and have single digit 1/4 mile times, exactly how hard is it to get your car to the point where it works on drag radials? ive been thinking about it and am not sure if i want to stay with the 17" drag radials or buy some 15" wheels and run a 275 or a fat 325. my car works well with them but still hazes them when i leave on it if i leave lower it bogs. input please. car is 6 speed, cam, bolt ons, nitrous, etc.
right now im leaning toward some drag type wheels
Old 09-17-2009, 01:38 PM
DADDY&GIRL93TA's Avatar
Got more options with 15s. That is my 2 cents.
Old 09-17-2009, 02:33 PM
dlove's Avatar
M&H makes a great 17'' DR. I went 10.3 @ 132 or so with them. At the time I had very little suspension work.
Old 09-17-2009, 02:40 PM
blk00ss's Avatar
Yeah if your going to do it on 17's, I suggest those big *** 325 17's from m&h. I went a 7.0 in the 1/8th on them. 6speed here as well.
Old 09-17-2009, 02:44 PM
dlove's Avatar
I was on the 275's
Old 09-17-2009, 03:55 PM
daniel6718's Avatar
you arent witha 6 speed...you need a slick or slipper clutch or slip the clutch to 60' real good
Old 09-17-2009, 05:34 PM
dlove's Avatar
nice catch, that's what i get for skimming the post
Old 09-17-2009, 06:56 PM
so since im a 6 speed go big tires?
Old 09-17-2009, 08:14 PM
KCFormula's Avatar
Unless you want to go through clutches all the time. I had my car to the track once on 17" BFGs and slipping the clutch I was able to pull a 1.71 w/ bilstien shocks and road race swaybars! But the clutch isn't happy.
Old 09-20-2009, 09:37 AM
any other input?
Old 09-20-2009, 12:58 PM
daniel6718's Avatar
you dont need big tires just bias ply...26x10.5 is fine...you just need a tire that will give more than a radial
Old 09-21-2009, 04:05 PM
86cutlass350's Avatar
im going to get my car to work on the 17's (turbo, 4l60) i beleave mighty mouse has gone 8's on 17's so it can be done but your friend will be double adj front and rear shocks.
and i would say a two step would help you be consistant once you get the car working.
Old 09-22-2009, 12:20 PM
procsls6's Avatar
I've been 1.55 60' with a cam only t/a that had nothing done to the suspension on a stock rear not trying to kill it.
