Ne1 know why brakes are rubbing
Friday i installed new rotor and pads on the front and today i installed the rear rotors and pads. After i did the fronts i noticed that the left tire after torqued to 100ft-lbs it has a very slight rubbing issue, the good thing is that is even with one complete rotation. The right tire doesn't do this, but the back two do it also. What can i do to fix it?
Is everything stock(wheels and calipers). Some after market wheels have a thin plastic piece that sits in the center of the wheel between the wheel and hub(not a spacer). Take off the wheel thats not rubbing and see if you have one.
