This doesn't belong in my oil pan!
I was changing my oil the other day and I found some metal on my oil plug... It wasn't shavings. It was a broken valve guide seal spring. WTF?! Now my question is what damage could it have done on its way from the head to the oil pan? Time to tear into the heads and maybe do some upgrading.
The spring that goes around the seal... I doubt it would have caused any damage unless it got between the rods or between the rods and crankshaft. If it had got between any moving parts to damage anything I doubt that you would even be able to tell it was the valve seal spring.
That means only three things could have happened. The seal was defective or the keeper to seal clearance is to tight. Or you floated the valve and the keeper or rtainer broke the seal ans spring. This clearance is very critical and often overlooked. How much lift do you run and what is the clearance seal to retainer?????
Fixed it
I tore it down this weekend. Took off the valve covers and started on the driver's side one spring at a time. Made it through 5 springs decided that I didn't want to go through every single spring by removing it and looking at the seal so I took a small inspection mirror and checked out all the other valve stems. I found the seal with the missing spring and replaced it. The mirror saved me a lot of time. Should have thought of that earlier but the with my dual springs I didn't think I would be able to see the seals. The one with the missing spring was also unseated from the valve guide and was just floating on the stem of the valve.
One pain in the a$$ was that we ended up dropping a valve lock and had to spend 20 mins looking for it in the engine bay.
As for the lift it is .595/.605 on a tsp 233/239 cam.
-The seal was probably damaged when we installed it due to having to tap it down with a hammer and socket because the seals don't have the seat attached
