For the ones building their own Front Mount setup...
Old 09-18-2009, 12:45 PM
Vcious04's Avatar
Default For the ones building their own Front Mount setup...
Well, found out today from my tuner that the turbo is not draining properly allowing oil to backup in the turbo cuasing oil to leak past the seal and into the downpipe. Just wanted to let the ones know that are in the process of building a lower front mount setup on a budget a scavenger pump is likely needed. Not too much $$ extra, but extra none the less.
The pump I chose is the 12VDC Version:TurboWerx Part # TWX-300-12V (About $450 to install and dial in). Having them install that along with a Turbonetics manual boost controller.
Oh well, I was planning on having it all tuned and dyno'd tomarrow, but I want to make sure it's all good.
To be continued!!
Old 09-18-2009, 02:14 PM
bgblockelcamino's Avatar
yeah have done same thing. just have to make sure turbo is up high enough. i didn't take into account there was rake to the car and if car facing downhill it will not drain fast enough
Old 09-18-2009, 04:55 PM
Tally TransAm's Avatar
out of curiosity how high is your turbo and where was the drain, any pics?
Old 09-18-2009, 05:14 PM
red90cobra's Avatar
Where did you have your drain?
To be continued!!
Old 09-18-2009, 05:23 PM
Vcious04's Avatar
This is about the best pic I have (at work). Feed is basically a stainless steel brake line, drain is 1/2" to oil pan on the drivers side just above the oil level.
Check the 1st post, that has some decent pics.
http://www.dfwstangs.net/forums/showthread.php?t=397379
Old 09-18-2009, 06:42 PM
ReApEr75's Avatar
Is that a KY kit? Or is it custom?
Old 09-18-2009, 07:03 PM
Pat-Man's Avatar
DIY kit
Old 09-18-2009, 07:28 PM
ReApEr75's Avatar
Originally Posted by Pat-Man
DIY kit
Gotcha, Thanks
Old 09-18-2009, 07:44 PM
devilssled's Avatar
hey thanks for the heads up, im starting my own diy kit
Old 09-18-2009, 08:09 PM
BlwnLs1GTO's Avatar
I'm running a scavenger pump on a TT system for a GTO.
I planned for this in advance to avoid the potential troubles. The turbo's drain would have a long way to drain with the way its' set up now.
Old 09-18-2009, 10:05 PM
Reject's Avatar
damn man owell that's an easy fix, at least your putting around alittle now
Old 09-18-2009, 11:58 PM
LS1Silverado05's Avatar
I've been a bit worried on mine, if I will need one or not.... My turbo is a liiiiitle bit higher than yours, but not a whole lot.... Think I would have trouble too and should avoid the headache and just do a pump from day one? (Pics on Page 2 in build thread in Sig) Thanks...
Old 09-19-2009, 12:15 AM
ssnovaturbo's Avatar
Little off subject, but does the return line from the turbo have to run at a 30 degree angle all the way to oil pan/timing cover, or just right out of the turbo? My turbo will be high enought for no pump, but just ? routing line
Old 09-20-2009, 11:28 AM
Vcious04's Avatar
I would say yes. You can buy the entry level pump from Turbowerx for about $250. I have heard you have to dial them in tho with nitrous jets/restrictors. I just said the hell with it and let my tuner install it and tune it.
A lot of it has to do with vehicle stance. If it's raked, imagine how it's gonna perform when braking. From what I have found out the turbo MUST be atleast 8-10" above oil pan to properly drain without a pump. IF I would have known this, I probably would have designed it different. Oh well, lesson learned.
Old 09-20-2009, 11:14 PM
Alright. I think Ill go ahead and commit to a pump before I run into trouble... easier that way!
Old 09-22-2009, 09:19 PM
Restricted User
1BAD_LS1's Avatar
Im hoping mine will drain fine.... if not ill have to save for like a month lol.
Quick Reply: For the ones building their own Front Mount setup...
