ABS question nobody can answer
I'll ask this a different way. I was wondering, other than a cleaner looking setup is there any advantage of changing from a 95 bird abs to the newer 98 abs?
It won't work easily without reconfiguring quite a bit more than swaping the controller. The cleanest look is to remove ABS using our ABS delete kit. I don't consider ABS as a perk no matter what year it's pulled from.
