loud squeeling help
Old 09-18-2009, 09:06 PM
mknight759's Avatar
Default loud squeeling help
I just installed a new never run ls6 into my s10 i run it for 10 min then changed the oil today was the first time i had it on the road it did ok for a little while now its making a loud squeeling noise even when i remove the belt could it be a bad cam bearing no nocking whatsoever sounds like a loose fan belt or something
Old 09-19-2009, 11:22 AM
Ph.D. in HUBRIS
custm2500's Avatar
It isn't the tires being roasted at all times is it? Just kidding. You best bet is to use a long screw driver and see if you can pinpoint the noise and where it is coming from.
Old 09-19-2009, 11:31 AM
mknight759's Avatar
yea it will get a little squirrly in second but i feel 90% its a cam bearing spun so gonna start disecting the truck tomorrow it is one more pain in the a$$ to get the engine out fenders and inners then jack the cab up to get it all out it if I didn't have bad luck I wouldn't have any luck
Old 09-20-2009, 07:22 PM
mknight759's Avatar
ok got the engine apart its not a spun bearing but looks like a little gaulding on the front bearing camshaft looks fine what do you think ?
Old 09-20-2009, 08:38 PM
Dean95z28's Avatar
That bearing looks great! I have seen some with the brass showing and they still work fine! I would look elsewhere. Are you sure it wasn't something like a small vacuum leak wistling, or maybe something in the tranny?
Old 09-20-2009, 08:50 PM
mknight759's Avatar
well not real sure it just sounded like a spun cam bearing or like a fan belt slipping removed the serp belt and noise still there sounded like it was in the front of the engine it did sound like metal to metal
Old 09-21-2009, 09:53 AM
muayyadf1's Avatar
EDIT
That cam bearing lookes worn to me..worn evenly. is there a difference between the lip and the body of the bearing?
Do you have a magnetic drain plug? metal shaving?
