Best lowering kit for a 17/18" wheels set-up?(PIC)
Here are some pics of my Strano Spring and Koni 4/4 shock setup. I am still running the spring isolators in the rear. I am also using an on car adjustable pan hard bar.
https://ls1tech.com/forums/wheels-ti...-trans-am.html
Do you have the stock springs and rear isolator in the rear? Seems low if its still stock.
rim size has little to no affect on lowering the car. its the outer diameter of the wheel that you put ON the rim.
so you could theoretically lower a car the same with a 15" rim as you do with an 18" rim...assuming the outer tire dia is the same.
not sure what you're really asking
Just a suggestion
We offer a 1.25 inch lowering spring that I think would fit the bill quite nicely. I attached an image for you to look at...Let me know if you have any questions or concerns
