Swapping the rear pullies on a 112?
Can you do it? It looks like you there might be enough clearance and it should get you a lb or two without dropping to a smaller front pulley. has anyone done it?
FWIW its a CTS-V setup. Im thinking if I can get leave the main shaft pulley the same and either get another one so its 1 to 1 or maybe a slightly smaller one. looks like itll take some grinding on the cover and lower section to actually flip them...
