Hydrolocked...Forged motor?
Old 09-21-2009, 02:43 PM
boostedrs's Avatar
Default Hydrolocked...Forged motor?
Well last night I was driving and I saw a car go through a flooded area and figured hey I should be alright...well I wasn't. My car is lowered around 1 1/2 inches and has springs on it and has the WS6 air box. So I decided to try and drive through it and about halfway through the car just dies. I had this happen before on another vehicle so I didn't start it. I get out and there is around 12" of water and up to the centercap on my wheels. So now I pulled the plugs out and am about to try to crank it. Will the insurance company total it? NADA shows it's worth like $8959. I have all the receipts for a forged motor with rods, pistons, cam, heads, and everything else. But I'm not sure what I need to do? If they cut me a check I can go about my ways to replace the motor if necessary, right? If I want to buy a block and salvage what's good in my motor.
Old 09-21-2009, 02:52 PM
DVS99TRANS's Avatar
If you did happen to get water in the motor, the insurance company may or may not cover it. Pending who you are insured with normally, you'll have to call them to see if they cover it. Sorry to hear about your luck, but hope you can get it running bro.
Old 09-21-2009, 04:07 PM
bjamick's Avatar
You may get lucky here, just drain the oil. Maybe it didn't do too much damage and it just died, bc water wet the plugs or something. I dunno, I don't drive through puddles .
Old 09-21-2009, 04:14 PM
chaman's Avatar
Man, I just dont see how it would have taken water just like that. I mean I know is lowered and all but still. Besides the WS6 box you happen to have a free ram air mod too?
Old 09-21-2009, 04:17 PM
boostedrs's Avatar
Yah it has that done to it too. So it has the sheet metal intake thing so it sucked it in through there. It was pretty bad when I took the lid off and looked in the throttle body. There was like an inch of water in there.
Old 09-21-2009, 04:20 PM
chaman's Avatar
Oh crap...now I understand. Hope everything works well for you!
Old 09-21-2009, 04:34 PM
NemeSS's Avatar
yea, ive been in water before too...
i just wait it out now, 2-3hr wait is cheeper than new engine and being on foot.
IWGF's Avatar
Compressing water doesn't work too well.
Old 09-22-2009, 03:10 AM
boostedrs's Avatar
***Update
Well I got the plugs out and cranked it over manually a few times. Then I went to the moment of truth... to fire it up. It cranked over easily and started idling kinda high, about 1300-1400 RPMS. So I listened to it and no knocks or anything so I just wanted to see what it was going to do. Then it finally caught an idle and sat at the regular about 900 or so. I let it idle for about 5 minutes or so then tried to pull it up and it started hesitating real bad then started to try to die. I haven't changed the oil yet but am going to before I try to start it again. So I'm not sure if I'm good to go or my car is going to be toast. But as of now it doesn't seem like anything is knocking or tickin so that's always a good sign.
Old 09-22-2009, 04:47 AM
13lu91rS's Avatar
you deff should have changed that oil and filter before trying to start the car. water and oil mixed is never a good thing!
Old 09-22-2009, 05:59 AM
darkhorizon's Avatar
unplug the maf sensor as well, or replace it.
Old 09-22-2009, 06:15 AM
SOMbitch's Avatar
Sounds like your o2's are wet.....
Old 09-22-2009, 06:42 AM
CarsandWomen's Avatar
if there is water in the crankcase then you just ruined all the bearings.
Old 09-22-2009, 08:21 PM
OMGWTFBODY's Avatar
Why the hell didn't you change the oil?
Old 09-22-2009, 08:33 PM
bballr4567's Avatar
X124359823456734956
You possibly just destroyed your engine with your second stunt. First one was pretty stupid, the second was inexcusable. People here told you to drain the oil before you try to start it.
Oil and water DOES NOT mix. It WILL NOT lubricate the drivetrain.
Also, you hyrdolocked one motor yet you still drove through water with a FORGED motor??
Old 09-22-2009, 08:37 PM
Fatbum's Avatar
Originally Posted by bballr4567
X124359823456734956
/everything I was going to say.
Old 09-22-2009, 10:29 PM
SOMbitch's Avatar
I think he would have heard knock if water had gotten into the oil but I am usually wrong........just ask the GF...
Old 09-22-2009, 10:40 PM
OMGWTFBODY's Avatar
Why take the chance? Once it knocks, you're likely screwed.
Jesus.
Old 09-22-2009, 11:30 PM
Formerly darynC-10/23/10
Daryn's Avatar
man dont u know that water is BAD!....
why would you drive through a flooded area and that car anyway? ...
Old 09-22-2009, 11:44 PM
ultraz's Avatar
Your insurance will NOT cover your forged motor unless you itemized it with them and they adjusted your premium accordingly. If you have full coverage, they will cover what a stock motor would cost with the mileage it has. I think I remember someone posting that isurance give these motors a 200,000 mile life expectancy, and adjust costs of replacing accordingly......... so if youve got over 100,000 miles u can expect to recieve less than someone who only has 20,000 miles.
