Anyone making 700rwhp on stock block 346/347ci single turbo
Old 09-22-2009, 12:09 AM
nasty_ss's Avatar
Default Anyone making 700rwhp on stock block 346/347ci single turbo
Just wondering setups leading to 700rwhp without bored blocks on single turbo.
Turbo:
Heads:
Pistons:
Rods:
Cam:
Compression:
etc. :
Old 09-22-2009, 02:13 AM
transamfreak01's Avatar
ur pushing it with stock internals. i doubt itll last long at all
Old 09-22-2009, 07:14 AM
smokinHawk's Avatar
i ran 135mph at around 3700lbs race weight so that should be around 700rwhp.
stock block bored .005 over to clean it up with JE flat top pistons and eagle rods., arp rod bolts, spinning it to around 7000rpm, with a PTE88 turbo.
317 heads, home ported, a 224/224-114 cam at around 8.9:1 CR.
Old 09-22-2009, 07:56 AM
sujomatt's Avatar
yea i hate to say it but u wont be seeing that # for very long if you do lol. id say a pushing it but will last # is 650 on a dynojet..
Old 09-22-2009, 09:06 AM
smokinHawk's Avatar
he's talking about a stock cubed block, not stock bottom end i presume.
but a built 356/347 can last quite long at that power level
Old 09-22-2009, 09:46 AM
JAX04's Avatar
its been my understanding that the block and crank will take what you can throw at it. its the rods, pistons, rings, etc. that need to be pepped up. weisco, arp, eagle, diamond, etc.
Old 09-22-2009, 10:33 AM
sujomatt's Avatar
oh didnt even realize, thx for clarifying haha
Old 09-22-2009, 10:54 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Turbo: GT47-88
Heads: All Pro
Pistons: Diamond
Rods: Don't remember
Cam: SI 236/236 something like that
Compression: 8:1 (don't reccomend this)
etc. : LS6 block, bored 3.910
RWHP: 867 rwhp, 25 psi
Old 09-22-2009, 12:09 PM
cause4panic's Avatar
too low? why?
Old 09-22-2009, 01:02 PM
LS1Tech Sponsor
Slowhawk's Avatar
700rwhp shouldn't be a problem on a 346ci/turbo.I'd go 9-1 comp and shoot for 12-14lbs of boost for the #.
Old 09-22-2009, 04:25 PM
LS1Tech Co-Founder
Too low, not needed.
Old 09-22-2009, 05:25 PM
TheFallen's Avatar
http://www.performancetrucks.net/for...24&postcount=1
I found this on the truck side. a 4.8 making 700 and lasted 7k worth of miles at that level
Old 09-22-2009, 05:53 PM
86MonteSS's Avatar
Chris Stewart is making 717/677 through an LS6. stock internals, block, heads, cam, intake. (C5Z)
only mods are injectors and TTIx turbo kit and an auto trans
Old 09-23-2009, 05:13 PM
V-seriesTech's Avatar
Myself(787rwhp-696ft-lbs) stock short block... aftermarket heads/cam/turbos.
Old 09-23-2009, 07:09 PM
mike13's Avatar
He puts alot of runs on his car 9.70's @142
Old 10-05-2009, 08:58 PM
LSXHawk's Avatar
Nice to see u created another name quik? I was wondering how u could make 700hp and only run 12.5s in the quarter?
Old 02-08-2011, 10:10 PM
nasty_ss's Avatar
what kind of fuel systems werebeing used?
Old 02-08-2011, 10:35 PM
turbo370supra's Avatar
venomws7 should be soon
Old 02-08-2011, 10:58 PM
black98ws6ta's Avatar
I made 800 rwhp with my stock bottom end 5.7 and a set of stock truck heads. A good tune, and good fuel can keep a stock motor together not to mention a built one. A motor with rods and pistons alone should be reliable for a very long time if everything else is right.
Old 02-09-2011, 06:59 AM
505OUTLAWZWS6's Avatar
I myself have been 9.93 at 136 weighing in at around 3600 with a stock block, rods, pistons and heads.
https://ls1tech.com/forums/forced-in...w-gt-88-a.html
Quick Reply: Anyone making 700rwhp on stock block 346/347ci single turbo
