5.3 stage 2 heads.....Gasket question.
Old 09-22-2009, 07:32 PM
red04ls1gto's Avatar
Default 5.3 stage 2 heads.....Gasket question.
I just read this:
"Both of these engines share a common aluminum head with 71cc chambers.. The 12559862 casting was used from '99-'04, but the 12561706 showed up on some engines in '04, too. The 862 casting came with and without the recess on the edge of the deck surface, so rebuilders need to make sure they use the right head gasket when installing one of these heads."
Anyone heard of this? I am putting these on a 04 GTO......So I assume I cant use the stock MLS gaskets then? Thanks guys...
Old 09-23-2009, 08:49 AM
T t t
Old 09-23-2009, 10:16 AM
My stage 2 5.3's have the recessed notch on the deck surface, and I would like to know what gaskets you guys are running with the same. Thanks!
Old 09-23-2009, 06:49 PM
T t t
Old 09-23-2009, 06:59 PM
SOMbitch's Avatar
Just call a sponsor>>>>>
Old 09-23-2009, 08:45 PM
hammertime's Avatar
Originally Posted by red04ls1gto
I just read this:
Perhaps that was a typo, but I thought 5.3 heads had 61cc chambers.
I bet one of the guys from Scoggin Dickey can answer your question. Good Luck!
Old 09-23-2009, 09:29 PM
rggbly's Avatar
i could have sworn they come from tsp with 62cc chambers...i think a lot of people have them milled to 59 though
