Drag Racing Tech
Will the Eaton Posi hold....
Old 09-22-2009, 08:34 PM
mike#9's Avatar
Default Will the Eaton Posi hold....
being dumped at 6k rpm on the track? Car makes 430rwhp h/c/i. How long do you think it will hold up? Also, what about throwing a 100-150 shot at it?
If I were to do it again....I would not get the rearend that I have........but I also did this back in 2003. How easy is it to change to a spool on a Moser 12 bolt? What kind of cost am I looking at?
Thanks and sorry for all the questions.
Mike
Old 09-23-2009, 06:09 AM
Race your car!
JL ws-6's Avatar
Spool is an easy swap in a 12 bolt, I did that last year. I did have an eaton posi in the car, and it held up to probably 100 bottom 12 second passes (stick cam only car, 3700 lbs) as well as over 100 mid 10 second passes off a transbrake/footbrake launch n/a, then some 9 second nitrous passes as well.
It will hold up better then the tru-crap's do by far, but a spool is a good piece of mind. Easy swap, pull the axles, pull the posi unit out, pull the ring gear, put it on the spool. and reinstall. Measure the ring gear position for tooth mesh first, and then try to reposition via the shims to the exact same spot. Or, just put some new gears in while it's apart, then you don't have to mess with trying to reposition it the same, just have to get the pattern on the new ones right.
Good time to adjust gear ratio if needed as well.
Old 09-23-2009, 08:20 AM
mike#9's Avatar
This coming from you is good to hear. I think I will run the Eaton for a while, and then if needed.....swap to a spool. How much was that swap?
Old 09-23-2009, 08:33 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I know JL personally and IF I knew I'd be blowing up 2 Tru tracs, I would have had him hold onto that Posi but you never know until it happens.
Old 09-23-2009, 10:32 AM
Race your car!
JL ws-6's Avatar
Spool swap wasn't too bad. I did new gears, all new bearings at the same time, I think it was about 500 bucks in parts. But, you can sell the posi unit and old gearset for about 500 like I did and recoup alot of the cost.
IMO, take the posi out and sell it now before it's broke and worth nothing, and the upgrade will be cheap
Old 09-23-2009, 06:37 PM
ls14jay's Avatar
Mine only seemed to hold up to about 50 mid 11's runs before it broke.I also went spool.
Not very street friendly but should hold up way better I hope. Seemed Fairly inexpensive to swap it over, even paying someone to do it.
Jay
Old 09-24-2009, 12:25 PM
mike#9's Avatar
Is it worthwhile to upgrade the axles while swapping out the center section?
Old 09-24-2009, 12:34 PM
Race your car!
JL ws-6's Avatar
If you have less then 33 spline axles then yes I would upgrade them to 33 spline, if you want to spend some big bucks, you can go to a 40 spline gun drilled star flanged axle, but honestly at your speed, I don't see that as nessassary. Plus, the gun drilled/star flanged axles for street use, I'm not too sure about that.
Old 09-25-2009, 12:35 PM
mike#9's Avatar
Is there a 35 spline Moser axle for the 12 bolt w/spool?
Old 09-25-2009, 03:16 PM
transdam's Avatar
broke my eaton on the 3rd pass my tru trak has been 75+ pass with no problems
Old 09-25-2009, 03:21 PM
Colin91Z's Avatar
What kind of axle do you have? 9", S60, or 12 bolt?
Old 09-25-2009, 03:33 PM
transdam's Avatar
33 spline 12 bolt
Old 09-26-2009, 07:04 AM
Race your car!
JL ws-6's Avatar
You're the only person in the country that's having that kind of luck with one. Like I said, I have 3 broken ones that I know how they broke first hand..... 5 launches and all 3 were done. I've seen 10 bolts last that long leaving the same way on a real tire.
Old 09-28-2009, 04:07 PM
omcar's Avatar
Default Eaton
broke 3 Eatons (springs/clips etc) with my A4 before getting an Auburn Pro..so far so good.
Quick Reply: Will the Eaton Posi hold....
