Best place to mount a tach without cage?
Been having some trouble out of my stock tach so instead of messing with it may be cheaper to buy an aftermarket. So I was wondering for those of you without cages in your cars where have you mounted your aftermarket tachs? Pics will be great!
thanks
thanks
I like the A-pillar location the best. I used to have the tach mounted directly to the plastic molding on the A-pillar with the tach resting on the dash but it kept moving around, vibrating and coming loose and to me, it just looked kinda cheesy. I ended up fabricating a mount that I bolted directly to the metal part of the A-pillar.
For the A-pillar mounting side it has 1/8" steel plate with two self tapping type bolts holding it to the pillar, then it has a 5/16" steel rod bent to shape and welded to it. Then for the tach mounting side I used a steel all-thread coupler and welded that to the end of the rod. The mount is very rigid (ie doesn't vibrate at all) and now it doesn't rub on the dash at all and it's far enough from the steering wheel that I won't catch it with my fingers when turning the car.
Mike
Mike
i love the a pillar but unfortunately i have the pillar pod so i guess thats a no... i want some in my view of vision but not something thats going to be annoying to drive on the street where its all in my face.
i know i want a autometer but are there any you recommend? are some more accurate than others?
'Bird Director
I bought mine from a member on here back in 2007. They were new & never installed. The seller needed the money for another purchase (I think it was an engagement ring), so I got a really good deal on several guages.
