wanna see what lean and to much timing does to a piston...
Old 09-23-2009, 10:22 PM
ATVracr's Avatar
Default wanna see what lean and to much timing does to a piston...
http://www.yellowbullet.com/forum/sh...97#post2933997
Old 09-23-2009, 10:32 PM
SLawson86's Avatar
damn... take it that would be your piston??
Old 09-23-2009, 10:33 PM
mitch cobb racing's Avatar
looks like a damn styrofoam plate you left in the microwave too long!
Old 09-23-2009, 11:14 PM
ATVracr's Avatar
yep.
its 3 pistons.....good thing we have a few extras.
Old 09-23-2009, 11:20 PM
Restricted User
1BAD_LS1's Avatar
lmao, mine wasn't that bad... it just took out the very edge of piston #7
Old 09-23-2009, 11:33 PM
Choppers's Avatar
that will most definately not buff out.lol
Old 09-23-2009, 11:48 PM
jmill96Z's Avatar
So....was it fastest before it let go? LOL J/K
That is some crazy ****. Any sign those 3 holes were lean before teardown?
Old 09-24-2009, 12:20 AM
daniel6718's Avatar
lean for sure...what happened? how were the plugs?
Old 09-24-2009, 12:25 AM
robsquikz28's Avatar
so how much were you spraying? How much timing was actually pulled on that setup?
Old 09-24-2009, 07:31 AM
ATVracr's Avatar
Old 09-24-2009, 07:39 AM
ATVracr's Avatar
It never let go, but it was on its way.
We knew #2 was hurt, we compression tested it Sat. morning and it was 130 ... We pulled some timing from that hole and ran it all day long.
#2 was the reason we tore it down but the other 2 being hurt was not much of a surprise. #8 didnt look to bad other than the ring land being pushed up.
Like I said on YB, we have been RACING this motor all year so I aint mad at it.
Old 09-24-2009, 07:42 AM
Z284U2TRY's Avatar
How much was that being sprayed with? Atleast the rod still looks good.
Plug?
timing?
fuel?
Fireball's Avatar
how did the rod bearings look
we're cracking mine open next weekend...I'm almost scared to see what we'll find
Old 09-24-2009, 08:03 AM
ATVracr's Avatar
We use coated bearings and they looked fine, the coating is not even off of them.
I was thinking the same thing you were before we pulled them off though.
Old 09-24-2009, 08:04 AM
ATVracr's Avatar
Plug?
timing?
fuel?
450hp
Tr11
9*
165lbs. or so
Old 09-24-2009, 08:42 AM
JAX04's Avatar
WOW, thats pretty, lol. well atleast you got a good season out of her anywayz.
what kind of piston is that?
Old 09-24-2009, 08:48 AM
LS1 SPEED's Avatar
it will happen and as you said for a season of racing and fly'n like you are you can't be mad
Old 09-24-2009, 09:11 AM
brians91formula's Avatar
Looks like a weisco piston
Old 09-24-2009, 09:59 AM
WE TODD DID's Avatar
I don't believe that was lean, or overtimed. It pushed the ring land up, then let oil in the chamber. I bet it was rich. Any plug pics from that tune-up?
Old 09-24-2009, 11:22 AM
8 second mod
Noyzee's Avatar
rich is what usually gets the ring lands.
looks like the pistions took most of the pain, looks like the block may still be in ok shape and reusable with minimal clean up?
