9310 27 spline vs stock Z06 30 spline
Old 09-23-2009, 10:28 PM
ddcarter's Avatar
Default 9310 27 spline vs stock Z06 30 spline
Which one/ setup would be stronger? Is the TR-6060 mainshaft the same as the T56?
Thanks, Dustin
Old 09-24-2009, 06:37 AM
85MikeTPI's Avatar
The thicker 30-spline shaft is stronger, but requires a swap of both trans and rear to utilize it. The 9310 27-spline is a nice step up over stock and allows retention of all other stock components.
The TR-6060 units have a thicker output shaft, but not compatible with T56 components.
Old 09-24-2009, 08:24 AM
thesource's Avatar
The 27 spline aftermarket mainshaft is a stout piece. I've actually never had one break after being installed.
Old 09-24-2009, 08:26 AM
Kurtomac's Avatar
I had RPM transmissions put the 30 spline in my MN12 Trans...had their Level 5 upgrade too....they had to machine my pinion gear to accept the 30 spline and used the 3 rip z06 case still with the RPM stage 3 390 upgrade
Old 09-24-2009, 08:27 AM
Kurtomac's Avatar
RPM told me theyve seen the 9310s break...but not a 30 spline so...who knows...I made that stock shaft my bitch though on my 2nd pass with my twin disk
Old 09-24-2009, 12:11 PM
ddcarter's Avatar
How about before installed? J/K thanks again.
Old 10-14-2017, 08:43 AM
chevyguy3's Avatar
Old thread, but just wanted to add my experience for anybody searching this in the future.
Just broke a 9130 G-Force 27 spline main shaft in my car. Never had a drag radial or slick on the car, never been to a drag strip and I never wheel hop it. Just drive it on the street and autocross it. 767rwhp with a Dyad twin disk. Had Michelin Pilot Sports on the car for most of the 2 years the shaft was in the car. Currently have a Toyo R888 on it.
Old 10-14-2017, 10:54 AM
jmd
jmd's Avatar
I did.
Consensus of the owner was wheel hop did happen. 27 spline is just carryover for no good reason. The transaxle was fairly clean sheet design. No need to go with that size except "That's what we've always done and the vehicle GVWR is under x,xxx lbs." In the end, a diff. bolted directly puts more force and vibration into the unit than a cylindrical driveline that dampens things.
Quick Reply: 9310 27 spline vs stock Z06 30 spline
