IAT Style and Mounting...
Old 09-23-2009, 11:12 PM
LS1Silverado05's Avatar
Default IAT Style and Mounting...
Just curious what everyone is doing as far as placing your IAT in the intake piping. I have seen a few cars with the stock grommet and a few cars that have some kind of threaded in style IAT sensor....
It seems like the stock style grommet would be a prime place for a small boost leak... does anyone have trouble with it, or does it manage to seal up fine?
If not, where do you get the threaded style IAT? Thanks
Old 09-23-2009, 11:40 PM
bgblockelcamino's Avatar
i use the syclone one and thread it in. can't remember thread off hand thinking same as O2 sensor
Old 09-23-2009, 11:45 PM
Hmm interesting.... what kind of pipe is it going into? My pipes are aluminum so its not like I could weld on the O2 bung....
Old 09-24-2009, 05:33 AM
427's Avatar
The thread in one is 3/8 pipe, the sensor and alum weld bung is pretty common. I make my own weld adapters normally because some of the store bought type are to long and the temp sensor does not stick out into the airflow.
Kurt
Old 09-24-2009, 05:57 AM
Fireball's Avatar
I just bought a summit weld in 3/8 NPT bung and it worked fine with a syclone sensor...
Old 09-24-2009, 11:37 AM
Ok cool thanks guys....
So is the Syclone IAT plug n play or do you need a pigtail for it?
Old 09-24-2009, 11:42 AM
Fireball's Avatar
plugs right in
Old 09-24-2009, 12:48 PM
TX RED's Avatar
Part number on that syclone IAT
Old 09-25-2009, 11:37 PM
Ok I picked one up.... I see that it plugs right in for sure.... no tuning adjustment for calibrations or anything right? Reads like a stock one?
Old 09-25-2009, 11:45 PM
JonCR96Z's Avatar
Better hope not. There's no way to adjust IAT values.
kkslds's Avatar
yea i got one for a grand national GM IAT Sensor #25036751
Old 09-25-2009, 11:48 PM
Well in that case Im fine... or else all the guys that use them are screwed...LOL
Old 09-26-2009, 12:11 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I made my own bung out of a spacer bought from lowes. It was 5/8" OD and 1/2" ID x 1"long iirc. I cut it down to the length I wanted, then tapped it with a 3/8" NPT tap and welded it to my pipe.
https://ls1tech.com/forums/11950864-post81.html
Old 09-26-2009, 12:19 AM
Pretty slick Chad!
Old 09-26-2009, 12:31 AM
ChevyChad's Avatar
Thanks man
Old 09-26-2009, 12:34 AM
DevonsZ's Avatar
John, if you get a bung Mickey could weld it for you. I know he charges $50 per hour for aluminum welding, but he may cut you a break on somthing like that?
Old 09-26-2009, 12:37 AM
Anyone else in town weld aluminum? Yea I didnt like how my grommet fit, so I figured the hell with it I'll buy the bung/sensor...
I have to get the bung welded in, and also my Blow Off Valve flange welded on one of the cold pipes....
I guess I need to ask.. HOW MUCH when I show him the pieces...
Old 09-26-2009, 12:47 AM
DevonsZ's Avatar
I only know of him and the other place Kent went to the first and only time. Mickey does MUCH better work. I'd just stop by and ask how much $$$.
Old 09-26-2009, 12:50 AM
Yea will do. Its worth it for good work on that stuff I guess.
