Centerline 15" wheels
Old 09-24-2009, 12:15 AM
Kcssmaro's Avatar
Default Centerline 15" wheels
I was looking at buying some centerlines.
I really like the revs and was wondering how centerline 15s fit on a stock fbody rearend. Grinding? Spacer? Etc?
Old 09-24-2009, 07:19 AM
Camaro396's Avatar
Lots of it. And yep.
Old 09-24-2009, 11:31 AM
Kcssmaro's Avatar
So with enough grinding they will fit ok?
Old 09-24-2009, 05:41 PM
SLawson86's Avatar
define your definition of okay... i wouldnt drive on the rear calipers after grinding enough to clear ls1 brakes. my suggestion is spend some coin and buy drag brakes, or spend some coin and buy better fitting wheels. just my .02
btw, yes... i have centerline rev series, and i have compared. just not a match in a 7.5 bs. search on here, a fellow member used the qualifiers on his, not sure the exact story though. g/l either way!
Old 09-24-2009, 05:49 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
the convo pros dont require any grinding tho
Old 09-24-2009, 05:54 PM
SLawson86's Avatar
also meant to add, before you consider totally hacking calipers where they are FUBAR, think about the cost of these wheels/lugs/tires... you are in the 1100.00 range for wheels alone, add the price of lugnuts. just punching in bogarts in ***** shopping, came up with a set of new for a mustang gt d-10's, before talking to steve or seeing what he can do i came up with 1490.00 imo, not a bad price diff for the wheels...
steve, if this is incorrect, please feel free to chime in and i will edit the post
Old 09-24-2009, 09:18 PM
gillbot's Avatar
the 15x8 or 8.5 (i forget which) convo pro and warriors will fit w/o grinding usually. Sometimes you may need to knock the bur off the casting line though.
Old 09-24-2009, 09:24 PM
Kcssmaro's Avatar
Do billet specialties street lites fit stock brakes?
Old 09-24-2009, 09:29 PM
Turd Gen Guy
1nasty86's Avatar
they have wheels made to fit the rear of an f-body..... no gringing!
Quick Reply: Centerline 15" wheels
