Is this the right part/ part number for this seal???
I had to get the 10 bolt repaired due to bad bearings and some other stuff. Now yesterday I noticed a smell so i took a look under the car and something was leaking from the rear. It's leaking right where the driveshaft connects the the 10 bolt. The leak looks to be coming from that seal. So do i have the correct part and part number......http://shop.advanceautoparts.com/web..._R|GRP60008??? I've read that the seal i need is a 2 piece.
Get the seal from the dealership. In 01 they changed the design but early 01s still had the early style. Late 01s and 02s got the 2nd design. I cant remember which they call two piece and three piece or whatever.
one is a triple lip design(2nd design) and one is a 2 lip design(1st design) you want the triple lip design, go to your local gm dealer and get part number 12471523, regardless they are both 2 piece design
