ls6 cam or go bigger
this is the camshaft I am using I have a stock bottom end and a set of stock 243's for my heads i have the engine apart and was curious if anybody thought it would be worth it to go ahead and put a bigger cam in i know this one is bigger than the stock one inthe the f-body cars lts also an auto by the way Camshaft, Hydraulic Roller Tappet, Duration at .050 in. 204/218, Lift .550/.550, Chevy, LS1/LS6, Each
What are you wanting out of the motor? daily driver? weekender? Leaving everything stock or what? If you go with a cam, you'll need to replace your valve springs. What RPM range will you be seeing most of the time? What gears? Lotta questions need to be answered before swapping a cam. You gonna put in a higher stall?
its in my s10 gonna drive it everyday probably seeing more of the lower rpm's exept when my foots in it gonna change gears to 373 26.5 in tire I don't know much about cams so looking for any help is what i have a good combo
imo i think that the ls6 cam is pointless to put in. i just think that if youre going to take the time and spend the money you should get a little more out of it. and i would definitly get a converter. it is honestly the best mod i have done. if youre looking for a smaller cam get something like a 224. i have a 226 and it drives great. i take my car out for an hour or 2 at a time and have no problems
what about this one with a 2500 stall on 112 lsa and how much hp do you think i could expect from a cam change the engine should already be a little over 400
The Texas Speed 224/224 .581/.581 Camshaft With Your Choice of Lobe Seperation.
If you are gonna stall it that cam would be great but then why stop there I would go bigger.
But.... What is budget? Stall $600+, cooler $60, cam $389, springs $150-$250+, pushrods $100, tune $450+......
or used LS6 cam $100, new springs $60 and I would do pushrods too another $100
Or the middle ground..... Do something like a 220/220 wth springs and PR's and run the stock convertor. I wouldn't recommend going bigger than 220/220 on a stock convertor though some on here do. I would still figure a tune in with this route....
AT THE MINIMUM, something along the lines of the TSP 228R. its by no means a big cam so it will drive, idle, and tune just fine while making a good amount of power, 390+ with all supporting mods. the ls6 cam really isnt worth it. some people like 224's, but for just a little more duration at no cost of driveability, etc. you will gain more.
So if i'm understanding this right, if I were to put an LS6 cam in my LS1 I would have to change my srpings as well correct? I didn't know if those springs would hold up or not,
