Put OEM C6 wheels on my car, and now my ABS keeps kicking in.
Old 09-26-2009, 12:00 AM
photoman9988's Avatar
Default Put OEM C6 wheels on my car, and now my ABS keeps kicking in.
So I put some OEM 18/19 C6 wheels on my '99 WS6. I used the 1.25" adapters in the rear. Now, every time I brake, I can feel my ABS kick in, and it makes it difficult to brake. I have the stock brake setup and stock suspension. What can I do to fix this problem?
Old 09-26-2009, 12:03 AM
1998Z28LOADED's Avatar
What is the tire size? The overall diameter needs to be within 1/2 inch or it will trigger the ABS. I have OEM with 295/30 rear and 275/35 front with no issues.
Old 09-26-2009, 12:05 AM
295/30/19
Old 09-26-2009, 04:28 AM
DaddySS's Avatar
265/35/18
295/30/19
There's your problem: the 18s are 25.3 and the 19s are 26.1
Old 09-26-2009, 08:05 AM
So what should I do?
Old 09-26-2009, 08:48 AM
BandDirector Blk98ZM6's Avatar
Go to a 275/30/19 which would make the rears 25.5" tall...however, the ride will be VERY rough! That's the main reason I ended up ditching my C6's and went back down to 18's all the way around w/275/35/18's.
Old 09-26-2009, 09:39 AM
spaulsen's Avatar
ive got c6 wheels, 305-30-zr19s on rear, 255-35-zr18s in the front....no issues whatsoever....
Old 09-26-2009, 04:09 PM
spy2520's Avatar
temporarily i guess you could disable the ABS.
Old 09-26-2009, 04:21 PM
DaddySS's Avatar
If you replace the fronts with a 265 40 18 it will be 26.1 also
Old 09-26-2009, 09:06 PM
Formulated's Avatar
Would a simple reflash of the ECU to calibrate the tire size / speedometer make this problem go away?
Old 09-26-2009, 09:30 PM
Not every car has issues with the difference in OD.
Old 09-26-2009, 09:33 PM
IMO the easiest solution is get on ebay and pick you up a pair of used 275/35/18s. They are one of the most common 18's, you can find a pair with 60-70% tread left for under $100 shipped almost any day.
Old 09-27-2009, 09:12 AM
but would 275's even fit on 18x8.5's? I thought 265 was pushing it...
Old 09-27-2009, 01:01 PM
DaddySS's Avatar
Let's start with what brand tires you have now?
Old 09-27-2009, 07:29 PM
Tudds's Avatar
Does the ABS light come on?
Old 09-27-2009, 09:18 PM
Im pretty sure thats a 18x9 wheel
Old 09-28-2009, 09:33 AM
I have Pirelli P-zero Rosso's on.
Yes, my "ABS Inop" light comes on, and does my "TCS off" light. Also, every now and then when I first start up my car and take off, my "Low Trac" light will come on and REALLY screw up my braking until my abs light comes on.
I think they ARE 18x8.5 They are '09 C6 wheels, not Z06. They are the split spoke 18x8.5 and 19x10 i believe.
Old 09-28-2009, 09:58 AM
Major_Lee_Slow's Avatar
spaulsen's car is a 98 which had a unique ABS system vs. later years. photoman9988, what year is your car?
Old 09-28-2009, 10:10 AM
'99 with an '00 SS motor.
Old 09-28-2009, 08:20 PM
DaddySS's Avatar
Looking at the pirellis, if you replace the fronts with 255 40s you'll be within .2 and will not trip the ABS.
