LS6 Intake swap
Old 09-26-2009, 02:36 AM
99LS1zul8r's Avatar
Default LS6 Intake swap
i just bought this LS6 intake, are the only things i need to buy the 2001+ coolent lines? sry couldnt figure out how to resize image.
Old 09-26-2009, 06:08 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Keep the stock LS1 coolant lines and knock the "ribs" off the bottom of the intake. Here is what mine looked like afterwards
Old 09-26-2009, 06:16 AM
frankmarroquin's Avatar
You can either do as above and shave the ribs down or I have even seen where ppl mold the existing line to fit underneith. Or chose 3 and get the 01+ setup.
Old 09-26-2009, 05:36 PM
99LS1zul8r's Avatar
did u just grind the ribs off or do i need to grind a little deeper where the lines are run?
Old 09-27-2009, 02:49 PM
Z28/2002's Avatar
Just knock the ribs flush with the bottom of the intake
Old 09-27-2009, 07:02 PM
ACLR8R's Avatar
Ditto, just took a hammer, a chisel and about 10 minutes.
Old 09-28-2009, 11:46 AM
kevins2000LS1's Avatar
Can you still run the stock LS1 throttle body?
Old 09-28-2009, 01:26 PM
redbird555's Avatar
Yup theres no difference
Z28/2002's Avatar
Yes you can
Old 09-28-2009, 02:32 PM
tribaltalon's Avatar
so if you knock the ribs off, its a straight swap from ls1 to ls6? or do you still have to do other things? going to a ls6 intake would gain me another 20-25 hp with my cam. hmmm..
Old 09-28-2009, 03:11 PM
slt200mph's Avatar
http://ls1howto.com/
This link will give you a step by step with photos on how to do the insall. This mod should give you about 24/17 for a nice performance increase.
Old 09-28-2009, 03:30 PM
Mike454SS's Avatar
You'll have to block the EGR ports off on the exhaust as well and remove the EGR valve as the newer intake has no place for the EGR tube to go.
Old 09-28-2009, 06:47 PM
1sicss's Avatar
I would have a oil pressure sending unit on hand just in case u can get it at Oreily's or AutoZone if u don't need it just take it back.
Old 09-29-2009, 07:57 AM
slt200mph's Avatar
If you lift the intake straight up instead of leaning it back when you remove it you will not break off the oil pressure sending unit.
Quick Reply: LS6 Intake swap
