moser 12 bolt abs question
no problem its a direct fit. both the abs and tcs read from the same sensor so there the same plug. make sure to weld the SMALL 1/2-13 bolts to the T.A. or it will come loose and have very expensive repair
No, it is not going to work unless you drill a hole in that carrier and install a reluctor wheel on the pinion gear. So it's cheaper to find another 12 bolt for a 3ch car, or just ditch ABS and run it that way.
