Which bottle to buy??does it matter?
Old 09-26-2009, 03:21 PM
waltsfastz's Avatar
Default Which bottle to buy??does it matter?
Im fixing to round up a couple or 3 bottles for my LT1 fogger setup. Not shure how big of a shot I will go, maybey 300-350 if I can get the car to go down the track. Which bottle is the way to go. Is there a diffrence in them? Any suggestions appreciated
Thanks
Old 09-26-2009, 04:30 PM
BAKED's Avatar
Having a high flow valve is nice but not necessary if you are just going to spray 3-350. I would however recommend getting a -6 main feed line if you don't already have one.
But to answer your question, any bottle will be fine. You can usually find some old used ones for $75-100.00
Old 09-26-2009, 11:11 PM
waltsfastz's Avatar
Thats the plan running a 6 AN line. Ive got an Old Nitrous works bottle that needs a new adaptor and hope to pick up a couple more.
Thanks
Old 09-27-2009, 11:27 AM
ShiznityZ28's Avatar
I like pro flow bottles but the NS bottle is good.
Old 09-28-2009, 05:12 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
If you are buying used bottles....please...please have them certified before using them.
Old 09-28-2009, 10:04 PM
waltsfastz's Avatar
OK, Who recerts them and how much does iy usuallyrun to get it done?
Old 09-28-2009, 10:51 PM
MelScrilla's Avatar
it seems like racers run whatever bottle is handy, I've seem many guys mix and match with two different name brand bottles in the car at the same time.
Old 09-28-2009, 10:59 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
any local welding supply shop can get the bottles re-cert'd
Old 09-30-2009, 12:40 PM
Iyyob's Avatar
U can even use old fire extingushers ect just about any c02 certed one will work
Old 09-30-2009, 04:29 PM
Chris@NitroDaves
Guest
Posts: n/a
Originally Posted by Iyyob
U can even use old fire extinguishers etc just about any c02 certed one will work
Or make it to look like a Fire Extinguisher
Old 09-30-2009, 09:03 PM
waltsfastz's Avatar
Ha, Sneeky
Old 09-30-2009, 09:21 PM
MelScrilla's Avatar
Don't tell everyone why my fire system makes my car go faster.
