Advance or Autozone head gaskets ok?
Well i had to pull my driverside head off to have a exhaust manifold bolt removed for the header install. Im wondering if i had to get new bolts? If so are the parts store bolt and head gaskets ok to run???
definately need new bolts, i reused bolts once on my LT1 and the head lifted, and it was a stock motor, as far as head gaskets, ive gotten the felpro ones from autozone a few times and never had a problem
GM MLS are the best, pretty much never leak. A lot of folks run the Autozone gaskets and say thew work well for the price, apparently they are not always felpro either. The replacement head bolts are pretty much the same quality no matter where they come from. I would use the GM ones or spend the money for the ARP bolts. Are you going to do both heads or just the one you had fixed?
just the one i had fixed. I need a link to the torque spec on the head bolts and intake bolts also. Anyone have a link?
This was a site that has been passed around a lot. http://www.ls1howto.com/index.php?article=3 The torque specs and sequence are towards the bottom of the page. Since you are just doing the one head I would get a single gm gasket so you have a better chance that it will be the same thickness as the one on the other side. Not sure how close the AZ ones are to GM gaskets.
I'm pretty sure there is more than one dealer, so that's a tough question to answer...
Some charge list price (major $$), some will charge wholesale if you schmooze them, etc.
