Fueling & Injection - LS6 to LS2 injector Question...
chopperloco
09-27-2009, 07:48 AM
...my C5 Z has a 383 with an LS2 intake/fuel rail(spaced up),but LS6 injectors!
I now have LS2 injectors and have the harness adapters coming...if i go ahead and install the LS2 injectors will the car run with the present tune and how well?Enough to drive it a bit till i can get re-tuned?
Thanks-Dominic
69LT1Bird
09-27-2009, 08:19 AM
Why screw around, either get it tuned to the new injectors or wait until you are ready to get it tuned and then put the injectors in.
chopperloco
09-27-2009, 10:41 AM
...because the nearest tuner is 5 hours from me.
69LT1Bird
09-27-2009, 11:03 AM
Why are you changing them?
chopperloco
09-27-2009, 03:13 PM
The ls6 ones do not fit the ls2 intake correctly,plus i think this engine could bennifit from a bit more injector...
69LT1Bird
09-27-2009, 03:33 PM
Your tuner would have been able to tell you that. If it was tuned properly with a wideband O2 sensor and the right information monitor like injector duty cycle and injector pulse you would know exactly. You should't just guess.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
