LS6 to LS2 injector Question...
Old 09-27-2009, 08:09 AM
chopperloco's Avatar
Default LS6 to LS2 injector Question...
...my C5 Z has a 383 with an LS2 intake/fuel rail(spaced up),but LS6 injectors!
I now have LS2 injectors and have the harness adapters coming...if i go ahead and install the LS2 injectors will the car run with the present tune and how well?Enough to drive it a bit till i can get re-tuned?
Thanks-Dominic
Old 09-27-2009, 10:52 AM
carlrx7's Avatar
hmm.. probley run like shizzzit. but as long as your current ltft's are not wayyy negative. the injectors are only like 12% bigger. if your running in CL then you could probley make it to the tuner. i dont know how far off the offset table is though.
Old 09-27-2009, 03:15 PM
Default Thanks...
...any other thoughts?
