E85 tunners look at this.
I got the OFI turbo car up and running, but have a few question about general idle and driveability (ve, timing, c3601 to c3510). It is still rich at Idle, but not that bad once I get the car moving. It does not free rev like I like (sluggish), but it does have 8.8:1 comp. Here are some specs below and my tune. Please look at it and give me some pointers if you like. I am new to e85 tuning. EFILive, COS3.
370, good heads, Comp Cam turbo cam 228/226, 597/574 on a 115, A BBK SSI intake with 80 mm TB, 57 pound injectors, Aeromotive Pro fuel system with a sumped tank. OFI turbo system, turbonetics t76 ball turbo, and tubular turbo headers, auto, 3600
Did more work today and I am now up and running. I also discovered the alt is bad, but just a couple setback and I can start auto VE tunning. Here is the better tune.
PLEASE NOTE!!!!! If anyone wants to use the tune I attached above, The fuel gauge segment is from a 2002 van and is using a 94 sender. So you may want to keep that in mind.
