Generation IV Internal Engine - Cam in a ls2 opinions
View Full Version : Cam in a ls2 opinions
Frametwista
09-27-2009, 10:47 AM
Just wanted to get some feedback on this cam i got installed in my stock ls2 comp cams hyd roller .588in .595ex dur@.050 228/232 lobe sep 112+4 like i said its a stock al ls2 400hp.I got all the supporting mods for the cam installed what kind of power from the motor should i expect thx n advance o yeah it has a ls6 intake the car has lt ory
Braciole
09-27-2009, 01:28 PM
Cam is a little on the smaller side IMO. I have an LS2 also and went alot bigger. Mine isnt installed yet, so no #s. You should be around 430 440whp with stock heads. Thats my guess. Do you have stock gears? If you go with 4.10s the LS2 really responds! And you can go alot bigger with the cam. because with the T56 in 6th gear you will be at 2200rpm at 70-75 mph so no surging or bucking;):burn:
Good luck keep us posted:nod:
Braciole
09-27-2009, 01:32 PM
woops, just saw you have the auto trans, which one do you have A4, A6,
you definately wont want 4.10s with an Auto. 3.42- 3.73 depending on trans
yonerhottlt1
09-27-2009, 02:16 PM
Thats a decent sized cam IMO that should make good power under the curve and throughout the powerband. Should make good usable power as opposed to just the peak hp that you would get out of a bigger cam.
Frametwista
09-28-2009, 01:37 AM
yeah it looked kinda small to me too and i have stock 3.42 gear car was originally m6 swapped in a a4 for now this is a cam that was recoomended by a performance shop i have a 78mm kytp kit thats going on the car probably this winter i have to get more supporting mods b4 throwing it on so i needed this cam to do double duty make power na 4 now but also work good with the turbo when the time came thx for the feedback i will keep yall posted
Braciole
09-28-2009, 08:43 AM
A4 trans you want 373 gears. The gears will allow you to go with a bigger cam too. it will keep the rpms up to keep it from surging and bucking. Your in
Good shape bro. Get the gears done in feels like 50 to 80 whp upgrade.
If the cam isnt installed go bigger IMO. The cam you have will be easy to sell.
That thing is gonna rock and roll!:nod:
Good luck
Frametwista
09-28-2009, 01:23 PM
thx bro i sure hope it will roll out pretty good i would like to see at least 12 os out of it
