Western Members - CalSpeed LS1 Mustang goes over 140 mph on stock LS1 bottom end today @ famoso
CalSpeedPerformance
09-27-2009, 05:43 PM
Well im still sitting here in disbelief....If you arent familar with the car ,this is on a bone stock 98' 88k mile 5.7l LS1 shortblock,
-stock casting 5.3l heads, EFI /w stock LS1 PCM, moderate camshaft (233/239), Victor JR EFI intake /w sheetmetal elbow /w 90mm throttle body, 28" M&H Slicks, 3.73 gear, th350 /w EDGE custom converter (stalls around 3k on footbrake)
I ran my car friday in the 102 degree heat and went 10.07 @ 134.9 mph...with a pretty weak 1.6 60ft leaving off idle and standing on it.
I didnt race qualifying yesterday and left my car out there in a friends pit. I showed up out there about noon today, since I didnt qualify I wasnt on the ladder to race. But they let me make a single pass even though they werent doing a open/test lane...
I put the 100 rwhp jets (125hp flywheel) in the single NX fogger. I figured ill crack off a sure thing 9 second pass and get kicked out since car isnt certed in the 9's yet.
Weather was 103 degrees, 130+ deg track temp...another horrible slow, 4000 Density Altitude day. Most faster cars were off 3-4 tenths due to greasy hot track and crazy hot.
Results:
Left on the WOT switch hard as I could , Car spun REALLY HARD for about 75 ft, peddled and short shifted 2nd gear and it hooked up and it just TRAINED out the back door to a 141mph!
Sad part....since it spun horrible and wasnt really a clean pass. It went 10.01 @ 140.2.... I was like "Are you kidding me! Im cursed to not click off a 9'sec pass in this car"
This corrects to a 9.67 @ 146 and I think its got a 9.40-9.50 in it with no changes on a great winter day in the coming months (dec/jan) and more mph because I feel it wasnt nearly as clean of a pass as it could have been.
Timeslip (which ill scan and upload tommorrow at work):
60ft - 1.617
330 - 4.326
1/8 - 6.522
mph - 112.21
1000 - 8.411
1/4 - 10.014
mph - 140.20
djsanchez2
09-27-2009, 05:51 PM
:thumb: :thumb:
What suspension you running?
CalSpeedPerformance
09-27-2009, 06:05 PM
:thumb: :thumb:
Car is all Wolfe rear parts and has best of everything BUT I need to scale the car, reset the pinion angle, rear spring/shock height and Im thinking about ditching the 28x10.5 M&H slicks for some 325/50/15 MT Radials.
SUCK MY SS
09-27-2009, 08:10 PM
i thought it had the stock cam in it for some reason... i dont think you mentioned the cam in the other thread... damn good mph though... seems like its got a lot left in it.
180ls1
09-27-2009, 08:25 PM
unported 5.3 heads?
Qwiknotch
09-27-2009, 09:00 PM
Jim, I could have sworn you had Racemaster DOT''s on it, not the full slick, when you teched it in....
CalSpeedPerformance
09-28-2009, 12:00 AM
MMMmmm sad part is I cant remember without walking out to go look at the car. Maybe they are the DOT ones. They were brand new 10 passes ago...so far no luck. I dont want to rule them out till I recheck pinion angle, shock/spring settings, anti-roll bar etc... I think ill order some 325/50/15 MT Radials tomorrow and try them out at my next track event (Mid october @ Fontana probably)...
Qwiknotch: man you must be happy to be out of the heat...you spent 3 long days out there....crazy hot out there.
Qwiknotch
09-28-2009, 11:37 AM
Actually, I only spent Friday and Saturday morning outside... Once qualifying started, I was in the tower doing the website updates... But even inside oin the a/c, we could feel the heat through the walls.. It was crazy and the track temp on Sunday was a little over 135 degrees
What do you have on the front for rate? with that light little engine, I would put 110-125 lb springs on it, unless you go blown or turbo.
The rear, all of my cars in the past loved 4 - 5 degrees of pinion angle. One of them, on a 26/10 , would run 1.41 60's and run 10.30's @3000lbs
CalSpeedPerformance
09-28-2009, 12:56 PM
Fronts are 150lb springs right now... Im still finishing up the 440" LSx 6-bolt blower motor for the car just need to spend some more $ to get it done. Ive got a new F2 Procharger LSx Cog drive kit in the box for it that will be going on with it.
Its going to pickup a couple hundred pounds in the front with all that stuff, tracks are closed for quite a while now, so i might have the new motor in it next time depends on how things go I guess..
Great event, had a good time. Tell Tim Rigby I really appreciate him letting me make a test'n'tune pass even though they werent allowing them.
socal gto
09-28-2009, 01:17 PM
Have you posted it up on the mustang boards yet and listened to them bitch about a chevy engine in a ford car? j/k. I honestly wish I could get a side car to work on. Hell I would love to have a fox body with a ls engine in it. Less expensive parts for the chassis and a proven power making engine.
ericg69ss
09-28-2009, 06:40 PM
Results:
60ft - 1.617
330 - 4.326
1/8 - 6.522
mph - 112.21
1000 - 8.411
1/4 - 10.014
mph - 140.20
Nice work and Congrats! What does the car weigh?
CalSpeedPerformance
09-28-2009, 07:37 PM
2760 with n20 kit (was 2720 without)
ericg69ss
09-28-2009, 07:52 PM
Nice... Certainly wish I could get my pig below 3000lbs race ready. Going to try but not very likely. Congrats again and keep us posted!
camscam02
09-28-2009, 08:50 PM
the car is a fox body mustang, so i think he says it weighed something like 2400 w/o him in it. wish I could have that weight. haha
CalSpeedPerformance
09-29-2009, 10:14 AM
With the n20 stuff on it now, its about 2520 plus me (was about 2480 without n20)
