Dual wet nozzle jet ?
Ok so right now i'm running a HSW wet kit and have been running a wet 125 shot and just came upon a nitrous plate the requires a wet nozzle per side so i will have to split the shot in half or take it up just a tad so what i'm asking is what size jets do i need to get as close as possible with out going under my current shot..
Also what plugs do you guys use with your 125-175 wet shot and what gap, i'm curently runing NGK TR6.
Thanks
Thanks
Guest
Posts: n/a
If this is going on a LT1 I would not suggest placing a nozzle behind your throttle body.
You run the risk of adversly affecting distribution if you do. A nozzle was intended to be placed in front of the TB to give the mixture room to fully atomize the fuel.
Yes you are correct. People spraying small shots have got away with it but it is a bad idea and poor design. Look how close your front runners are to the disharge of the nozzles. These nozzles are aimed at the back of the intake and when the discharge sprays out it passes up the front runners over powering the back runners. As an affect you are not equally distributing the nitrous through out the motor. Years ago we did alot of R&D with the LT1 and we tested the poorly designed plate you are talking about as well as the poorly designed plates that had spray bars aimed at the back of the intake. I can tell you the one you have is the worse out of all of them.
There is a reason why our LT1 plates are designe the way they are and why people are safely spraying over 200 on the stock LT1 intake with our plate.
Why risk it? If you are going to use a nozzle or nozzles place about 3 inches before the throttle body and give the mixture time to attomize into the airstream. If you want the plate look by one of our plate conversions. Our plate conversions are cheaper than a motor.
Just my 2 cents.
Dave
Just my 2 cents.
Dave
Ok i get what your saying but at the same time i don't see how anything except direct port system will equaly distribute a shot into a engine..Maybe it's just my thinking but i would think a nozzle like you mentioned in front of the throttle body would be eaten up by the front cylinders.. Maybe this plate isn't the greatest design but not every one has 285+ the shipping cost to switch to your plate...
If you like the look of having the discharge behind the throttle body you need to use a product that is designed properly for the job.
Does not matter to me what you do. Its your motor. I am just trying to share with you the education that years of experience, R&D and testing has given me. I spent lots and lots of money for knowldge I am telling you for free. Use it or not does not matter to me. I am just trying to be helpful.
Im simply saying keep what you have with the nozzle in front of the throttle body. No money spent and you have a method that will produce better results than buying a poorly designed plate that places the nozzle you already have behind the throttle body.
Dave
