Car leans out in first gear.
Old 09-29-2009, 12:42 AM
4bangermustang's Avatar
Default Car leans out in first gear.
Going over some logs, we noticed the car was leaning out pretty bad in first gear. Once second gear hits, everything seems to work out fine. I assume the pump can't keep up from the initial hit of the kit.
It is a wet plate kit, the noid is going to the stock rails, with an upgraded pump.
anyone else run into the same prob?
There anything to help with it besides a standalone or upgrading the pump?
Like I said, once the car hits second gear, everything is fine.
Old 09-29-2009, 01:03 AM
daniel6718's Avatar
upgaded pump as in what?
hotwire kit or no?
how big of a shot?
where are ou spraying from and to?
and how long is the car lean for?
how much gas in the tank?
got a fuel pressure gauge?
Old 09-29-2009, 01:21 AM
255 walbro
has hotwire kit
small shot, 100.
right out the hole.
all of first gear.
no
Old 09-29-2009, 07:36 AM
n2ocamaro's Avatar
I was having fuel pressure problems on 1 Walbro pump and hotwire kit pulling fuel off the rail on a 100 shot. I added a 2nd intank pump and fixed it. Not sure why would have a problem in just first gear though.
Old 10-01-2009, 12:51 AM
daniel6718's Avatar
what kinda power on motor and how fast does it 60'?
im guessing gas is sloshing or its spiking the rail...but unuseual on a small shot...new fuel filter!
how lean is it going?
Old 10-01-2009, 08:11 AM
Not sure on the power. 400RW?
We'll have it back @ the track in the next week or two and will try it with more gas in the tank.
gets leaner and laener as the RPPM's climb, prob 18:1 IIRC.
I'm pretty sure he is just spiking the rail.
Trying to talk him into this setup so we can log Fuel pressure.
http://download.efilive.com/Tutorial...20Tutorial.pdf
