Need Your Thoughts
Old 09-30-2009, 08:48 AM
Quick99TransAm's Avatar
Lightbulb Need Your Thoughts
Have Prc 2.5 5.3 heads looking at the ASA cam What
do you guys think of this power wise i have seen good numbers cam only so was wondering what the addition of heads whould do to this cam
Old 09-30-2009, 09:01 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Give us a call when you get some free time & we can talk over camshafts to match that cylinder head & your goals. I personally really like some of our new TSP camshafts that are designed to make power earlier & across a broad power range. The 229/234 camshaft on a 111 is a great option. With right around 620ish lift it can be run on a good single, or double spring setup.
If you'd like help selecting a cam just give us a call, I'm sure we can collect tons of engine dyno data to make your choice as easier!
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
