Iron block OK as a stressed frame member?
I'm installing an iron block 6 liter into a malibu with custom engine mounts. they use a urethane leaf spring bushing to isolate vibrations. The crossmember is notched and I expect some twisting of the frame during suspension travel in the a-arm area where the engine mounts tie in. so should I tie the engine mount stands into the area near the upper a-arm mounts which will stop the frame flex, making the engine a stucturual frame member or will that break the sides out of the block?
The engine has full truck accessories including a/c, and it's a turbo car. It will have forward cage struts and bracing from those struts to a-arm area. but I'm sure some forces will still be transmitted through motor mounts to the side of the block. I've seen a lot of dirt car blocks destroyed from wrecks breaking the mounts out of the side of the block. I guess my question is are gen III blocks much stronger in the mount area, is it safe to use the block as a structural member or am I much better off transferring as little stress to the side of the block as possible? G-bodies are very prone to wheel stands and although that's not my intention it will probably happen at some time.
