Msd window switch
Old 09-30-2009, 05:11 PM
TA1364's Avatar
Default Msd window switch
Trying to figure out where I get the rpm signal from. Is it the blue connector, white wire pin 35 on the pcm? If so....where is that? Help me some here.
Old 09-30-2009, 05:34 PM
Chris@NitroDaves
Guest
Posts: n/a
Here is an alternate ( Easier ) location to pull for the Tach
Male side of the plug top row of wires second from the left
Hope this helps
-Chris
Old 09-30-2009, 05:42 PM
RsSean's Avatar
That is what I have done for the last several nitrous installs. Have not had a problem out of it.
Old 09-30-2009, 06:19 PM
TA1364's Avatar
Same for 98 cars? Do I just strip some of the wire back and solder the wire from the msd on?
Old 09-30-2009, 09:37 PM
TA1364's Avatar
Also, how do I test the noids with the window switch wired in?
Old 09-30-2009, 10:24 PM
Ph.D. in HUBRIS
custm2500's Avatar
To test you can feel them and rev the car. You should feel them open and close. If you want proof you can make a mess and put your nozzle in a bottle or something so that it isn't blowing into your motor. Then you would see the fuel and nitrous coming out.
Feeling them should be plenty good but it is up to you.
P.S. Other ways would be to test with a volt meter to see if you get juice
(power not nitrous)at the noids, take it for a spin around the block.
Old 10-01-2009, 10:19 AM
TA1364's Avatar
So I am going to rev it to 3200 in the garage with hand on the noids? Lol that should be interesting.
Old 10-01-2009, 10:43 AM
Ph.D. in HUBRIS
custm2500's Avatar
I rev often with my noids in my hands.
Old 10-01-2009, 07:35 PM
TA1364's Avatar
So how do I hold the noids, rev the car and trigger the wot switch....
Old 10-01-2009, 09:30 PM
gsxr1k2's Avatar
Old 10-05-2009, 07:53 PM
Ph.D. in HUBRIS
custm2500's Avatar
Hope this helps
-Chris
I have a 2001 GMC truck does anyone know if this wire is the same for me?
Old 10-06-2009, 03:02 PM
Chris@NitroDaves
Guest
Posts: n/a
It's the same but might be a different color wire. I've seen them Solid Green - Light Green w/ White Tracer - Turquoise
Old 10-06-2009, 04:27 PM
Ph.D. in HUBRIS
custm2500's Avatar
passanger side or drivers? or will either side work?
Old 10-06-2009, 04:51 PM
Chris@NitroDaves
Guest
Posts: n/a
passenger side
Old 10-11-2009, 09:25 PM
TA1364's Avatar
So how exactly do I connect these wires? Whatever i did the car runs like **** now.
Old 10-12-2009, 05:09 AM
Ph.D. in HUBRIS
custm2500's Avatar
My wire was green with a white tracer like you said.
Did you split the wire for tach input? Maybe you didn't get a good connection of the original wire. Ideally you want to use a pair of automatic strippers that will just cut the insulation and open it up a bit.
Old 10-12-2009, 07:36 AM
TA1364's Avatar
Yea I soldered it on, the connection is good.
Old 10-12-2009, 11:07 AM
TA1364's Avatar
I took the wire off, car runs fine/ It started throwing a code from that wire.
Old 10-12-2009, 02:52 PM
TA1364's Avatar
Ok that picture must be wrong for 98 cars. I wired into the white wire, pin 35 on the blue connector. Works perfectly and no codes.
Old 10-12-2009, 04:46 PM
john563's Avatar
Hurry up Sam so you could hook up a kit for me! Oh btw will be at that place 2morrow (tues) around 9:30ish-10
