Cadillac CTS-V - Help with belt tensioner
View Full Version : Help with belt tensioner
needactsv
09-30-2009, 07:17 PM
I have an 04 V with a Magnuson supercharger. The belt tensioner broke and according to the local parts store computers, the tensioner I have on my car is not the stock tensioner. Anyone know if a different tensioner is used with the magnuson kit, and if so, do you know what it comes on from the factory? this thing looks like a typical GM belt tensioner.
Thanks,
Bucky
CTSV_510
09-30-2009, 07:21 PM
It is different from stock. I don't know what car it is from.
jerrad
09-30-2009, 07:37 PM
Can you find a part number on it somewhere?
needactsv
09-30-2009, 07:49 PM
i found a part number, but it doesn't cross reference to anything I can find(doesn't really look like a gm part number). I found a tensioner at the parts store, but the stud on back is clocked 180 degrees out. It has to be a stock GM tensioner. I know magnuson didn't make a new one for their kit. 3154162 is the only number I can find on it.
I'm on magnuson's website now trying to find it. Thanks for the help.
needactsv
09-30-2009, 08:07 PM
the dayco 89202 is the closest i have found on the net. only difference is this one has a smooth pulley, and the one i have has a 6 groove pulley. cant tell what the back looks like, may have the stud clocked(in wrong position) wrong.
punishmentcycle
09-30-2009, 10:19 PM
why not just call magnuson?
needactsv
10-01-2009, 09:06 AM
I am today
Stepside
10-01-2009, 05:47 PM
You need to contact East Coast Supercharging in Cream Ridge NJ or go to their web sit, eastcoastsupercharging.com. They have made a special heavy duty tensioner for exactly your problem.
needactsv
10-01-2009, 08:54 PM
thanks for the help, but it looks like a stock tensioner with a 8 groove pulley and some sleeves to position the stock tensioner out some. I'll just buy a manual tensioner for 50 bucks before i do that.
needactsv
10-04-2009, 11:24 AM
the part number needed is 89222. it is made by dayco and is the exact same that comes with the magnuson kit. You can buy it at Advance Auto Parts for about $56.00. Magnuson wanted almost $200 for it plus shipping. It took a lot of searching, but I found it and now it's documented if anyone else ever needs one. The pulley is different on the tensioner, but they have the correct pulley too.
jerrad
10-04-2009, 12:47 PM
That's great news for the maggie guys.
slvrvee
10-04-2009, 03:39 PM
When I came back from Sumit Pointe this is what I noticed
http://i22.photobucket.com/albums/b332/Sho9ice/IMG_7154.jpg
So I called up Magnessuen and I dont remember who I spoke to but he said that I could use the tensioner that comes in the maggie kit for the Vettes. It provides a lot more tension and should keep the belt from riding up. Part is Dayco No Slack Automatic Belt Tensioner Part #38131. I paid about $90.00 including shipping. You could get it at any auto store for a lot less and its a direct fit no modification necessary.
SIDE BY SIDE COMPARASION
http://i22.photobucket.com/albums/b332/Sho9ice/IMG_7696.jpg
http://i22.photobucket.com/albums/b332/Sho9ice/IMG_7695.jpg
needactsv
10-04-2009, 04:44 PM
my belt looked just like that a minute ago. I drove it yesterday with no problems and no squeaks. went out there today to get in, and the damn belt was 1/2 off, thought maybe I missed a groove. put the belt back on, and now it is squeaking like hell. It was squeaking before the tensioner broke. I think I might have another problem which is causing the squeaking and tensioner alignment. I'll keep you posted.
deedubb
10-04-2009, 04:46 PM
When you say it helps belt ride-up, are you talking belt slip? Or is that different?
needactsv
10-06-2009, 07:20 AM
Well!!! Belt shreaded again. SOMETHING HAS TO BE MISALIGNED OR SOMETHING.
jerrad
10-06-2009, 03:09 PM
You might take the belt off and grab each pully/idler and see if there is any play in it.
needactsv
10-06-2009, 06:39 PM
I checked the pulleys briefly, but did not find any problems. I guess I'm gonna mess with it more when I feel like it.
jerrad
10-06-2009, 07:11 PM
Raven had the same thing happen and it was the tensioner. If I remember right he said the bearing froze and the bearing kind of wallered around and became out of alignment.
raven154
10-06-2009, 07:26 PM
Yeah on the tensioner pulley the tolerance between the bearing and pulley was to great which cause the bearing to spin in the pulley and wallered the hole out and I was throwing belts until I got that fixed. After that I shredded one more belt but I think that was just a fluke because I never had another problem after that.
needactsv
10-08-2009, 06:06 PM
I have a new tensioner and new bearing. It threw it again today. I raised hell yesterday 100mph, no problems. today normal driving, the belt came off. I looked like the tensioner pulley was misaligned. I took the bolt out and put it back in, and now it looks aligned, but I'm not to sure. It has to be something simple, but haven't found it yet.
wmskateteam
10-29-2011, 02:08 PM
i know i'm reviving this thread, but I need some help and those part #s above are not working out for me. The Gates 38131 and 89222 both cross reference each other according to the NAPA computer but I am unable to use wither with the style of bracket that I have on my car. I don't have access to a camera, but the 38131 has a flat mounting area with an arm that extends directly out to adjust the belt which would require a flat tensioner mount. The tensioner I have installed has a recessed circular mount and the tensioner I removed from the car has a circular mounting area and the arm extends from the top portion of the tensioner only therefore not interferring with the recessed mount. I know this is really confusing and I will try to get a picture posted if I can, but if any of you have any other part #s or advice I would appreciate it. You can actually see the difference in the tensioners in the photo above. How could they mount on the same bracket? There are also no useful #s on the tensioner itself
raven154
10-29-2011, 04:30 PM
Get the dayco tensioner from Advance. The gates is different and won't work.
wmskateteam
10-30-2011, 10:01 AM
the tensioner i have is the same in the photos in the prior post. does magnuson send a replacement bracket as well? raven are you running the dayco?
9t8z28
11-02-2011, 02:45 PM
Is the tensioner bending or is it an issue with the pulley and bearings?
raven154
11-02-2011, 03:02 PM
I do rum the dayco bit don't recall I'd it's on a special bracket or not.
joehernandez86
11-03-2011, 10:20 AM
Might want to talk with 1badcts he had some tensioner problems with his superchager setup granted it is a whipple he might have some insight.
Twitch1
11-03-2011, 06:16 PM
This was on an 04 Maggied V and looks exactly like the gates on Amazon. I guess you need to use your old pulley.
http://i80.photobucket.com/albums/j177/Gxxr1/IMAG0118.jpg
wmskateteam
11-11-2011, 01:50 PM
just to follow up, i had to purchase a replacement tensioner bracket as well as two bolts from magnuson which totaled $36 + ride. The bracket is marked LS3 corvette and the tensioner was for 87-95 f150,e150 in case that helps anyone. So if you are upgrading your tensioner to the beefier version you also need a new bracket from magnuson
