how much compression is lost by flycutting
LS1Tech Premium Sponsor
On a stock LS1 short-block with 243 (64cc) heads, by cutting a 2cc valve relief you stand to drop about .3 on your static compression. That's enough to plan for, IMO! While you've got it apart, mill the heads down a bit to get some compression back out of her, and make sure to cut enough to compensate!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I seem to recall reading an .080" deep intake notch will be about 1cc.
This of course varies on how large of diameter cut you are making too. Cutting a 2.125" dia notch for an intake valve will obviously remove more material than cutting for a 1.6" exhaust valve.
Since you are cutting both .100" deep, -2cc would be a reasonable estimate.
When I cut mine, I planned on a 2cc loss for compression calculation purposes. When I got to actually cutting, and checking p/v, it turned out I didn't need to cut for the exhaust, and didn't. So my 11.5 compression goal suddenly became 11.67.
Which has not been a problem.
sounds good i did mill the head .025 and used cometic .040 gaskets i had just been wondering what my compression ratio was approx i figured it would be arround 11:1. i have been tring to run down what my power loss down low is coming from. car has super slow take off not sure if i need a bigger stall, currently vig3200, i figured raising the compression would yeild more tq for take off not loose some.guess i need to mess with tune first.
