VRX6 Camshaft
VRX6 Camshaft
Im Just Wondering If Anyone Is Running The VRX6 Camshaft From Vengeance Racing... I Was Debating Between That Cam And The Ms3 Cam.. Mods Listed In Signture.
Thanks
-Dan
Thanks
-Dan
Internet Mechanic
I have their VRx4 which is samller 228/230 which I like. For either cam your going to need more stall and if stock, more gear to get the most use out of them.
The biggest issues with top end cams is that their power in the low and mid range, with at least stick cars are can up the rpms on the launch, with auto cars you can go from spinning to bad bogging in no time.
I would check the hp/dyno section for results.
I Eventually Will Throw A 4000 Yank SS Stall In.... Then Car Came With The 3200 When I Bought It... Im Just Tryin To Plan In Advance... And Im Going To Go With A 12 Bolt From D.T.S With 3:73's In It.. Soo One Day Everything Should Match Up Eh?
