Need help tuning with efilive using a .hpt file
Old 10-02-2009, 08:10 PM
firehawkclone's Avatar
Default Need help tuning with efilive using a .hpt file
Im not very good with computers and even worse at tuning a pcm with one. Just like the title says, i have a .hpt file that C.A.T.S will not load and im clueless on how to get EFIlive to load it. EFIlive won't even read the pcm or take the vin#, im sure its something im doing wrong
Any help would be priceless(still searching....)
Old 10-02-2009, 09:06 PM
jay_lt4's Avatar
efi live, hptuners, and c.a.t.s. all use a different file format and you cant use files from one format with another software
Old 10-03-2009, 05:36 AM
poconojoe's Avatar
Actully you can normally interchange the files between the programs as long as you extract it from the PCM as a bin file. I have Ytied this with HPtuners, EfiLive, and Tuner Cat, and they will all open the same extracted BIN file.
Old 10-03-2009, 09:19 AM
Anyway to get into the pcm with another program?
Old 10-03-2009, 09:27 PM
poconojoe's Avatar
Not that I know of, if you can get it in to the PCM, you can get it back out with TC as a BIN by using the Test switch
Old 10-04-2009, 01:13 AM
I didn't get the file installed, but i did some poking around in EFIlive and got the few Mil's turned off that kept popping up.
My first tune job
