Procharged TA, pesky squeak! Please help!
I can not figure this out for the life of me, I have taken it to a shop and they dont even know. Has anyone ever encountered this? I'm pretty sure its coming from the back of the motor/tranny area. Could it be a torque converter? Or can they even squeak like that? If so what would cause that? I wanna fix this soon cause its annoying lol.
Thanks for any help! Video below.
2001 Procharged LS1, 5psi, 26,000 miles, Automatic.
http://www.youtube.com/watch?v=8E1Fuijzy0A
it might sound like its coming from the back of the block, but i would consider checking the bearings in the supercharger. Thats just one thing i would check into looking at, i dont know if you did already, or not.
It has to be something spinning because when you turn the car off you hear it slow down and stop. And its more audible under the car than on top.
Checked all the belts, all tight, checked tranny fluid, its good. I'm just out of Ideas
New updates, driving its very faintly there. When I stop and put it in neutral, drive or reverse and rev to to about 1000 it stops. let off the gas and it starts doing it again.
Think its the bushing? That hard to change?
Is it with AC on or Off?
Mine sounds the same - with mine it's the AC or the tensioner pulley.
When I start the car with the AC on - it makes same sound as yours. Start the car with the AC off and it does not squeak.
Mine sounds like yours too like it is coming from inside the engine near the back passenger side but it's my AC pump that is squeaking.
