No Lemon
10-03-2009, 03:06 PM
My wife parked her car and turned it off. Everything was working fine. The next day she goes to start it and it wont start. It cranks but wont fire.
I checked the fuel pressure and it is high 50's with the key on but falls to 0 after a few seconds. Regulator problem? I don't think this is stopping it from starting?
I hooked up a timing light and cranked it over but didn't see any flashing.
I hooked up a scanner and I got 2 codes. P1637 (Generator L-terminal circuit) and P1626 (Theft Deterrent Fuel Enable Signal Lost). I cleared the codes and now I only have the P1637.
I replaced the crank sensor and same thing.
I replaced the ignition relay with a new one and same thing.
I had the aftermaket alarm removed and same thing.
I tested the key an it shows 1.088 ohms
I tested the socket with the key in and it shows 1.19 ohms
I tested the resistor by itself and it is 1.09
I tested the resistor tapped into the vats wires and it shows 1.19 ohms.
I tried starting it with the vats hooked up and bypassed and same thing,
The security light stays on for about 5 seconds then goes out with the key in the on position.
Fuel and volt gauges work, has oil pressure when cranking.
I loosened and re tightened all the ground straps I could find.
I disconnected the battery and cleaned terminals.
Let me know if you have any ideas.
