so we tore down my Va Speed LS2 366 turbo motor today
Old 10-03-2009, 10:05 PM
Fireball's Avatar
Talking so we tore down my Va Speed LS2 366 turbo motor today
after the coolant and oil mixing failure a few weeks ago, I finally took the bullet back to shawn for failure analysis.
liners #3 and #5 cracked bad. combustion was leaking thru the liners and blowtorching the block. It was pretty violent Funny thing was it took time to cause the damage we saw...the 7.99 was on a definately hurt motor
cyl #3
cyl #5
torched deck
head gaskets were intact.
Slight leakage around the middle 4 cylinders...30+ psi is just too much cyl pressure for regular ARP std size head studs
on to the bottom end....
rod bearings were all PERFECT.
pulled the main caps...factory powdered metal caps held just fine at the ~1700-1800hp level. pinned mains did their job...no cap walk
thrust looks almost new after 40 passes....ATI has their sh%t together when it comes to keeping the converter from pushing on the crank
very minimal crank flex...completely normal for a traditional-counterweighted lightweight crank. It had some light wear on the center main bearings.
bottom line...the moroso pan and melling oil pump work well and showed no evidence of oil starvation...motor was ~8100 rpm at times...
obviously the block is trashed, so we'll be replacing with a used LS2 "****" block I found...plan is to resleeve with heavy-wall liners up the bore size to ~4.125...
Old 10-03-2009, 10:33 PM
venom ws7's Avatar
I said it once and I'll say it again you guys did a freaking awesome work with this engine and whole project.
I see you have 98X For sale so whats next?? 106mm
GOOD LUCK.
Old 10-03-2009, 11:12 PM
Tiago's Avatar
Great results out of the motor, good luck on the new build.
Old 10-04-2009, 11:16 AM
Restricted User
98Z28CobraKiller's Avatar
How'd the heads look? Any damage to the deck?
Old 10-04-2009, 11:25 AM
Fireball's Avatar
no..it was all under the head gasket...
Old 10-04-2009, 11:36 AM
InconFormula's Avatar
So i take it Memphis is out for you or you gonna try and make it?
Just Buy Phils 106, im sure hes itching to put a 114 on anyway if he hasnt already!!
Old 10-04-2009, 11:58 AM
MelScrilla's Avatar
Thats crazy, 1700 hp on a stock block with stock mains, people always say a aluminum block cant live like that but I'm sure you would habve been fine at about the 1500 hp level.
What crank did you guys use in that motor?
Old 10-04-2009, 11:59 AM
veee8's Avatar
I got a motor and a 106, just pick up some 295's Brian!
Old 10-04-2009, 01:47 PM
Fireball's Avatar
turbo kit is all cut up...redoing everything now
Old 10-04-2009, 01:48 PM
Fireball's Avatar
callies magnum xl
Old 10-04-2009, 02:34 PM
Shearer's Avatar
A little JB Weld and she'll be good as new!
Old 10-04-2009, 07:01 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
As you can see it is the liners that fail once you start pushing major power. The material of the block doesn't make a difference as the liners are all cast iron.
Old 10-04-2009, 07:50 PM
427's Avatar
The liner would be fine if the parent material supporting it was strong enough. I think this kind of failure is normally from deck distortion because of the way the LS blocks are designed.
Kurt
Old 10-04-2009, 09:02 PM
NA$TY-TA's Avatar
Dang man.... going for it now....
Old 10-05-2009, 06:18 AM
Fireball's Avatar
Kurt
all cracking was on the thrust side...we had the aluminum well supported with hardblok...I'm pretty sure having a ductile sleeve in there will definately help matters...I had many stresscracks on the deck, but only sleeve failures were on 3 and 5.
Old 10-05-2009, 07:32 AM
427's Avatar
Brian,
I have had the same problem with NA engines with o-rings in the deck. The basic design does not seem to play well with o-rings in the deck, just does not have the strength. We have switched Mike Brown to this design of o-ring, but his block has the bridge repair that seems to stop this type of breakage. You could stop this type of break with a reciever groove in the block deck, but then you will push water. You might want to consider the block bridge from ERL, I think it will stop this problem in the future.
Kurt
Old 10-05-2009, 07:55 AM
Shawn @ VA Speed's Avatar
we knew they were going to break-was alot of fun to find where.I have a fix for all of this,there is no worrys of it happening next season.
Old 10-05-2009, 07:57 AM
Big Bird WS6's Avatar
looks like time for a ERL block. lol
Old 10-05-2009, 08:30 AM
we will not be using an ERL block.
Old 10-05-2009, 10:04 AM
cause4panic's Avatar
Do all the piston's have signs of detonation?
Quick Reply: so we tore down my Va Speed LS2 366 turbo motor today
